Totally Overestimated my Ability - Heavier Rider Help - Dropped by Roberge
I think Chad used to refer to that as “brittle fitness”…I always used the term “surface fitness”, but the same concept.
If all your rides are short, intense efforts, you lack a sufficient foundation for long-term aerobic gains and performance. Yes, you can get “fit”, but as Fergus notes, it isn’t durable. Even a short period off the bike will cause significant fitness degradation. If you build that aerobic base, your fitness gains become much more sustainable.
Do you have a week snap shot of what you are doing from your calendar that you would be willing to share? Curious what plans you use as rough guide and what you are modifying.
I did the mid volume pol plan to get ready for Lumberjack and it worked okay, but I ended up riding that around .65IF and wanted to be able to try to ride closer to .70-.75. This year I want to do something similar but instead change the endurance in the pol plan to the upper end of the zone, and make the threshold rides harder without the extra volume TR adds to make 80/20. The VO2 stuff in the plan felt plenty hard and was going to leave it alone, with the occasional change to a 30/30 type of workout.
Do you update your FTP in intervals.icu frequently or keep it the same because when you increase your FTP CTL will decrease for doing the same efforts
You’re saying you built your engine in exactly the way I’m describing for a few years until you hit a plateau, then you raised your volume. This is all inline with my suggestion. The OP has ftp 245, not 300. There is a lot of meaningful improvement before they need to increase volume.
It’s not ‘mean’ or ‘rude’ to say that if you have low power to weight, you will struggle with off-road riding. Rolling resistance is much higher off-road, and the low power output becomes much more of a factor. OP shared they are 41 and relatively new to endurance sport. They have plenty of room to increase power by a lot, holding volume constant. They shared that they are a bigger rider from a power lifting background. I suggest focusing on developing the engine before stretching into ultra endurance distances. I’m not just gonna suggest drink more sugar so you won’t bonk. Meaningfully increase your power through some disciplined structured work and you’ll have much more fun in the future. If you just want to increase the distance (at any speed), then get your nutrition right and ride slower. I took OPs statement of high motivation to meant hey are ready to lock in to structure and get to work. I believe my suggestion is optimal for the new few seasons for this rider.
Obviously you would be doing both. I hope you weren’t thinking I suggested to only ride intensely? That doesn’t even make sense. Endurance riding and recover riding is filler for the week. The focus of the week is to nail the two key workout days, that are intense. If you want to build a longer and longer long ride on the weekend, tone down the intensity to absorb the load, vice versa. Quite frankly, we probably are on the same exact page, but you got buzzed when I suggested a rider with <3w/kg who wants to ride faster shouldn’t be focusing on pushing up volume. I did not say and am not saying a rider with that profile shouldn’t ride their bike long. They should do what is fun and best for them. But if that rider has a goal of riding long distances faster, I wouldn’t suggest they focus on riding long until they spend considerable time focusing on riding shorter faster than stretch it. Quite frankly, if you can ride 5-20min a really fast, then it’s really easy to ride long at a lesser intensity. You might literally be pushing the pedals 50% less wattage. It becomes relatively easier, that’s a fact
:point_up_2: I really don’t think that this post was meant to be rude?
I think people have interpreted it as an insult to people below 3w/kg but I just interpreted it as them expressing an opinion that more gains will be had training at higher intensity.
Not saying they are necessarily right but it’s a valid opinion :man_shrugging:t2:
They wrote “keep your training below 90 mins” but people seem to have read “if you have an FTP below 3 w/kg you don’t deserve to ride longer than 90 mins” which is not what they have written :thinking:
I update any new FTP on all platforms, really annoying BTW (Wahoo, Strava, TP, .icu).
I got “buzzed” because that’s exactly what you said. But enough’s enough for me. You have your opinion and you are entitled to it. Cheers.
my power numbers were up high when I hit 2.88W/kg :rofl:
If I read the original poster correctly, before the gravel event he was doing Rolling Road Race (or Gravel) Mid Volume, which pre-AT looked like this:
he didn’t say which build, but speciality looks short power focused with a helping of threshold.
Pure speculation on the part of the OP. Not an actual data point.
Very true, but I probably should have clarified how starkly different the two events were. First was 100% paved, 1000ft of climbing in 80mi, aero wheels & 30mm GP5Ks, and did those 80mi in a little over 4hrs.
The other was Unpaved :slight_smile: where I was on 47mm pathfinders, 6800ft of climbing in 75mi (that I did), and it took me like 6 hours.
I think I did the whole plan (base then build) and it was short power focused. It was a lot of VO2 max workouts. My current Progression Levels are 3.7 End, 3.4 Tempo, 3.9 SS, 1.7 Threshold and 7.6 VO2.
I just switched to High Volume Polarized. Due to schedule, I really can’t do more than 1hr15min weekday mornings (preferably 1hr), but I can do every morning. Based on the responses and my own feelings, I need more base work, more Z2…and if I can do the volume, more volume. And definitely incorporate longer outdoor rides when I can.
Below is what I’ve been doing lately. As you can see I increased my volume quite a bit. A snap shop of my calendar wouldn’t really help you much as I had races, vacations and bike packing mixed in. So I’ve had to switch a lot around to ensure I still hit my goals.
Regarding which plans I used (post Lumberjack which I did a .68 IF / 8:10 btw) I was very frustrated with my fitness and stagnation for the past couple years. I should be sub 8 hours and I’ve failed that goal the past 2 years. So I decided to completely switch what I was doing and solely focused on raising my CTL to as high as I could get it for the rest of the season. That started with a return to Base, a re-build and eventual peak to my last race on October 28th. I used Polarized Base and Build as a guide, turned off AI adaptions and focused on volume. Basically just hard workouts Tue/Thurs and Saturday something steady (tempo or MTB). All else was z2 at 65-70%.
If you want to ride that way for fun then have at it because it is fun. If your goal is to ride fast, then don’t bother to ride that long with regularity because it’s suboptimal training, in my opinion. You and others attacking my position because it differed from your opinion is literally the opposite of ‘everyone having a right to their opinion’.
Your past training is still too high-level to give any reasonable advice. There might be some disagreement on the thread, but all we can do is offer general training guidelines and personal opinions.
I’m going to answer your original TR Polarized vs Base/Build question at the end, but because I called KW rude, I’m going to outline how I both agree and disagree with some of his points.
So a little novella detour before answering that question.
FWIW I had a fantastic base of aerobic and anaerobic fitness in 2017, on about 6.5 hours/week average but a lot of intensity (more than any TR plan) and unlike what I hear on this forum I was able to push FTP out to 65 minutes, low threshold (90-92% ftp) out to about 2 hours, and 5-6 hour tempo rides. Then in 2018 I decided to try TR’s more structure approach, which resulted in (vs 2017) dropping average hours (5.75 hours/week during base1/base2), decreasing average-per-ride intensity (IF), while increasing the number of intervals. In hindsight it should be no surprise that I lost fitness, and to be honest all the intervals simply made me tired. And riding the trainer sucked.
Since 2020, all I can say is that taking a more traditional approach, increasing average hours to 7/week, with mostly endurance riding and fewer intervals, I got faster again (vs more structure / less time).
However it took 3 years to almost return to fitness of 2017, with year-over-year volume increases:
  • 2020 averaging 5.6 hours/week average, average duration of 95 minutes
  • 2021 increased volume 21% to 6.8 hours/week (+1.2 hours/week) and duration to 101 minutes (+6 minutes)
  • 2022 increased volume 9% to 7.4 hours/week (+0.6 hours/week) and duration to 115 minutes (+11 minutes)
  • 2023 had thumb/elbow issues, decreased to 6.8 hours/week and duration flat at 114 minutes, but (very) small increases in workout intensity to push fitness up and almost back to 2017
What surprised me the most was the improvement in my short power without even working on it.
I’m saying all this, and some stuff below, to say that @KWcycling brings up some good points.
My personal exploration of intensity got me the best fitness in my life at fifty five and season #2, but my intensity was somewhat polarized (I hate that word) in duration as I was doing 2-a-days. Training consisted of a lot of short 20-min morning commutes that were threshold sessions with at least one full-gas 45-90 second anaerobic effort, like this:
26 minute commute that morning, and an IF of 0.99 :joy:
Afternoon commute was 32 minutes
and an IF of 1.02 :joy:
Next day was Wed, group ride day.
Wed morning commute of 21 minute at IF of 0.94.
And then afternoon was 94 minute group ride at
an IF of 0.93.
On Sunday that week I rode at FTP for ~65 minutes and 0.94 IF for 2 hours:
and this was going on week after week, here is the following week:
Three flat tires that week, a banner week :tada: and why I switched to tubeless later that year. And look a few rare 0.79 IF rides on the 10th and 11th and 14th. Must have been slacking LOL, actually I was riding by feel and probably not ‘feeling it’ after the previous week’s Sunday 65 minutes at FTP.
Again, this all reinforces some of the clarifying points that KW is making.
BUT, and this is a BIG BUT (roll the music, I like big … :rofl: ), I was pushing up CTL at a controlled ramp rate. Rest whenever needed. Averaging 6-7 hours/week and then tossing in some big rides about once a month:
IMHO that is following basic training principles of progression and as much intensity as you can handle.
I’m sure some readers are shocked that WindWarrior, champion of endurance as a first principle, those readers are horrified reading those words :rofl:
I’m not recommending it. Just saying you are only limited by ambition and your self-coaching skills.
Thats why I have some agreement with @KWcycling but cranking up the intensity is like playing with sharp objects - you might get hurt :joy: And instead of W/kg I’d start with asking to see your power curves over various time periods, see how you responded to training, and review really basic metrics that is unrelated to your W/kg.
That said - my high-intensity approach 100% improved my endurance. My endurance rides from 2017 have the same power-to-HR as endurance rides this year.
Getting back to basic principles, with a job and family and limited recovery its easy to burn out on more intensity. And if you have some additional hours/week, increasing volume works for many and some coaches I respect believe that is true particularly if you have a young training age (this is my 8th season, still pretty young at training).
Thats another way of saying the last couple of years are so much easier versus 2017, and instead of 6.5 hours/week at silly high intensity, I’m averaging 7.5+ hours/week and mixing in some intervals.
Bottom line: my wife is happier, I don’t fall asleep immediately after dinner at 8:30pm, and I have plenty of energy to do 2-4 strength/conditioning sessions (mostly kettlebells) a week.
So if it was me, based on what I know now, and what I understand of TR polarized, I’d modify the workouts to things I know work for me. And do Monday-Thursday on the trainer at 75 minutes (5 hours mid week), and then 2-4 hours on Saturday and make that a hard group ride. Rest days of Friday and Sunday. So that would net me 6-8 hours/week. From what I understand of the TR Polarized base workouts, I’d swap out some of those as mentioned above. Less threshold during base, and more hard high-intensity (mix of full-gas and max efforts). But thats me, I understand what works and I know how to run experiments on my training.
If you don’t know what works for yourself, just stick with the plan as it should offer an average of +1-3 hours/week more than the TR plans you just completed. And I say you’ll be better off experimenting to find out if some additional volume helps or not.
Good luck!
thanks for the tag. Of course there’s a ton of other variables aside from the w/kg that should be considered, but I wouldn’t cap rides at 90 minutes soley based on w/kg.
pedal the bike for more than 90 minutes, it’s almost base season for north americans! those 3-4h gems are waiting.
scanned the thread, which became a bit aggro, so I’ll leave it at that!
No people are responding to you because using an arbitrary power to rate ratio to define the length or rides doesn’t make sense. It hits home for larger riders where it is hard to hit 3.0w/kg let along 4.0w/kg
Your other points about limiting too much intensity, focusing on raising power both make sense. You may have other valid points but your logic on your first post has triggered a lot of people because it doesn’t make sense and quite frankly it’s rude.
Power to weight ratios in cycling are commonly used as a metric to objectively define a rider’s level of fitness (this is a fact). For example, google the ‘Coggan power charts’. 3w/kg is not an arbitrary number that I conjured up to hurt feelings. It’s a strength to weight ratio of an athlete with a relatively underdeveloped aerobic fitness as you can see by looking at some data like, for example, the Coggan power chart or other similar things. I made many helpful suggestions to push that number up efficiently (weight and dieting was not one of them, so lay off about the ‘big rider’ stuff. I literally suggested focusing on strength, not weight, because if you’re doing the right things to gain the strength, the body tends to change accordingly). That’s literally the point of ‘training’. Riding for fun is good too (I do it a lot), but ‘training’ is riding with the goal to increase fitness. OP is motivated to train and increase fitness. I’ll stay out of these threads in the future to avoid hurt feelings, but don’t kill the messenger
It’s really not. You have a right to your opinion; they have a right to disagree and challenge it. :person_shrugging:
so if <3kw/kg means an athlete with underdeveloped aerobic fitness, the solution is to do shorter sessions instead of trying to do more volume to help illicit aerobic growth and endurance?
Another post from you of no useful purpose. Thanks for contributing to the discussion!
