I think you’re right about this, i think this is one of my bigger issues. For example, I tend to swim much better with a pull buoy, and when I try only kicking I am extremely slow. I think I could benefit from trying to improve this
Maybe need to try and focus on chest down, hips up? Then trying not to lift, turn, breathe, but rahter just turn and breath
Again, no coach here, just a background in swimming through college so let me know if this is confusing. I’m trying to find a good video that explains this.
In order to help teach body position we used a floating progression. You would start by floating face down with your arms at your side. If you do nothing your legs will likely sink and you’ll end up vertical. In order to counteract this you start by setting your body position, you want to think about engaging your core and keeping your spine in a “straight line”. Your head should be in line with your spine and your eyes pointing straight to the bottom. Good analogy is proper plank position. Then what you do is apply pressure from your chest to try and counteract your sinking legs while keeping that good spine alignment. This can be tough depending on your morphology, so you’re mostly learning what small adjustments to your posture in the water do to your position. Once you are comfortable there you move on to the next step, where you again float face down but with your arms out in front of you shoulder width apart. Again keep making adjustments until you can float with your legs up at the surface. This can take some time, but be patient with it. When you need to breath in either of these positions gently tilt your head up, without breaking your alignment and take a breath.
Once you are comfortable with that float, move to the next step, which will help with this. I will say I had coaches that disagreed on the order here, so I’ll give you my preferred method. What you will do next is start lightly kicking, keeping that good posture you learned in the previous steps. You want to drive this from your hips, don’t think about kicking your feet. IME it’ll feel like you’re really pumping with your upper legs. Once you feel like you can comfortably do a length move to the next step. In this step you’ll start with the float, then start kicking, then begin to rotate around the long axis of your body as you move down the pool. You want this to originate from your trunk, and think about your hips and shoulders rotating in unison about an axis through your spine (while your head stays in place). Keep your arms loose, the “low” arm will rotate underneath you, and the “high” arm will sort of just flop up on the surface. Don’t be afraid to go a bit extreme here, you’ll feel like your over-rolling, which is ok. You’re teaching body position and proprioception. Once you feel you have this, you can start slowly adding in strokes and breaths to the side. When you need to breath just think about including your head in the rotation. It does help to have feedback from someone on deck or video, to help reinforce what you feel you’re doing.
The one other point I would say is once you feel more comfortable with the body position and rolling, try and reach a bit more on your entry. You want to use your roll to reach out and straighten your arm before you start the pull phase of your stroke (without crossing the centerline).
Early Vertical Forearm. As i posted above it requries a lot of flexibility in the rotator cuff and elbos to actually get to that position. It does help with a better catch but triathletes are notoriously inflexible. Pure swimmers or Tri pros have more mobility and are able to employ it. I cant even get myself there anymore - darn age and pretending to be a Triathlete.
I feel like just that thought of trying to keep your elbow up high on the catch as you initiate the stroke is enough for most folk.
I personally really like a drill where you just do the front quadrant of the stroke then bring your arm back around when it’s underneath your shoulder. It’s a bit awkward at first, but at least the way we were taught enforced some really good catch mechanics.
Yep I haven’t had any issues, depends how rough the people are around you but I’ve never lost a cap. To be safe I put my goggles between the caps so if something rough does happen then I’ll only lose the top cap not my goggles
We used to do this stretch in college swimming (video 1). I still don’t understand what the point was, other than stretching your pecs.
I am no longer “swimmer flexible.” I’ve had 2 surgeries on each shoulder. Yet I still can have a very high-elbow catch. Maybe I’m missing some nuance in “EVF,” can someone enlighten this lifetime swimmer on what the difference between EVF vs High Elbow?
Edit: Is it just the nuance between breaking your arm at the elbow instead of using your “whole arm?”
If you look at Gerry’s second video he explains it. It’s after recovery, after reach, as you start the catch and pull, elevate the elbow to make the forearm vertical.
This is excellent. Thank you for the very thorough writeup and clear explanation. I will be sure to work on the float and adding in the kick and rotation as you suggested next time I go to the pool
Hi all,
Great to see this side of the forum! I’m new to the thread (and TR as well), but started doing tri 2-3 years ago (sprints, 15k run, HM, second half of the pack ) and am now training for my first half tri (either local or self-supported) early Summer with the MV half plan. First couple of weeks in now and I love it! The pools here (in the Netherlands) are closed. Do you guys just add in (some) extra Z2 volume on the bike to make up for the missed swimming? I was thinking of doing just more volume in base/build and then see in April once the water heats up a bit to go outside (or the pool). I’m not big on flexibility. Do you guys do a lot of band work as well? Love to hear your thoughts/approach!
Cheers,
Jitse
Sure, you can do extra cardio, but you also need to balance that with the missed quadrupedal-type cardio and strength. Swimming is as much about upper body muscle endurance as it is cardio.
