Thanks, I’ll probably order some flippers and gice these drills a try.
Maybe I’m opening up a huge can of worms here, but what’s the issue with the Early Vertical Forearm route? Doesn’t this just mean trying to rotate the arm early to get a longer pull?
Yes it is, but the flexibility needed to get the arm as early as prescribed is generally not there - I cant even do it properly even though I was a swimmer. The simpler thing is to just make sure the tips of you fingers are a little lower than your forearm and forearm a little lower than the elbow and you will start getting a really good catch. EVF requires quite a large rotation of the shoulder and elbow and it can actually get some injury if you lack the flexibility.
Quick question I’m currently doing the base phase of the full distance triathlon plan.Although I’m quite enjoying the training and not finding it over taxing,I find I’m spending a lot of my time in zone 3 for heart rate and power.I always thought the “golden bullet” for endurance training was to spend a lot if not most of your time in zone 2 to build the aerobic base for the hard work ahead.My concern is that once I reach the build and speciality phase I will be “burnt out” especially with hopefully the swimming pools open and the increase in running.Your views please
Basically the world of heart rate training and power training are similar, but they most definitely aren’t the same → an HR approach wont necessarily align to a power approach, and that’s largely because power is about output and HR isnt.
In short, I would not worry about your HR during power based training. Keep tracking it though and you are likely to see over time that your HR drops for the same output. As well as your maximum outputs increasing.
TR takes the approach of being more and more like racing as you get closer to race day - so you’ll see loads of hours spent at around 67% output in the last eight weeks, if you’re interested in HR as well as power it’s those sessions I’d be monitoring.
Got a positive Rapid Covid test this morning.
I think symptoms started Last tuesday as during my workout I noticed my sinuses draining a ton which never happens. Wednesday my throat was sore. Up until now it’s been super mild. Only sore throat and minor respiratory irritation. Hell, its been so mild my workouts haven’t struggled at all.
The only reason I got tested was because a slot was available when I checked this morning. I bailed on my workout today. Thinking I got in my head. Hoping this is as bad it will get
Never done Monterray so don’t know anything about it or the area. But I believe it should be a qualifier for 70.3 WC St. George. Usually we have all the races up to the end of June and beginning of July to qualify for the current 70.3 WC race. That has seemed, in the past, to be the point of which when races start to qualify for next years 70.3 WC race. In case for this year, looks like the last race to qualify for WC St. George is July 4th, 70.3 Andorra with the races after that race start qualifying for 2022 70.3 WC.
With Monterray on April 25th, it should qualify for the the current year WC, in this case 2021 St. George. I just suspect they haven’t updated the website. Could always email the race director to get a clear answer though.
As someone said above - tie your hair into a bun/ponytail first then tuck it into the cap. Never had an issue doing this (as a female with medium length hair). The caps designed for long hair are for like super duper long hair so they have more space in the back where the tied up hair would sit if that makes sense.
Also if I don’t like the cap I get at a race, I will double cap i.e use my silicone training cap underneath the crappy race cap hehe. Good luck!
Probably a mistake, Taupo 22 quali should begin after StG21. I qualified for StG already in September 20, which I think should have been a Taupo20 qualifier under normal circumstances.
I was able to take a 30 sec sample of me swimming freestyle, would greatly appreciate any feedback on my form. Might be better to get a side view in the future, but I think there is still much to be learned.
First time I’ve actually filmed myself. My own observations: Elbow looks a bit low, and hands get probably too close to the centerline. Any other thoughts?
This. Our pools have been shut since just before Christmas and at the moment the earliest they can open is the back end of February.
No stroke advice from me @steclark but I did get my own stroke professionally analysed in November and it was super helpful to have a coach on deck and then a video analysis to follow up. If that’s an option for you, you should go for it.
