The Ironman Training 2020 Thread
I’ve restarted the High Volume SS Base plans in the last week or two as my running races have all been cancelled. I hadn’t swum since Kona so that’s no real loss at the moment and as long as I stay well it’s a good use of time.
At risk of sounding like a public service announcement, please all be careful and follow the advice around social distancing and the like.
While I’m not by any means in the front line of treating those with COVID-19 I am an NHS nurse and some of the behaviours I’m reading about large numbers of people congregating to make the most of the spring like weather this weekend are just madness and will absolutely lead to more deaths that otherwise wouldn’t have happened. While most who contract the illness will ultimately be fine many will not and those could easily be my, or your, parents, grandparents or friends.
Racing will start again at some point so i’m trying to keep fit and treat now as another base phase of training. As for me, I’m still hopeful that moving to Perth will happen even if it is delayed by current events and I still have an eye on IMWA or the 70.3 next December assuming things are setting down by then.
Just restarted Mid Volume SS Base 2 plan as my A race might be postponed or cancelled (70.3 Aix).
6 weeks of this and hopefully I could switch back to to tri plan if we are allowed to run & swim. So, my A race is in August now, fingers crossed.
Be strong at home.
Well, with all the turmoil out there. I’ve decided to scrap my plan and start again.
I’ve left my ‘end of august IM’ as the only event, to give me something to build towards and re-planned via Plan-Builder
:man_shrugging:
Same here, I could put in the Base phase full distance and remove all the swims, I’m 28 weeks out from IM Barca, but even that seems optimistic.
I’m going to see if I can easily cope with 3 bikes per week on SSB LV2 combined with 3 runs per week out of Run Less Run Faster 10k plan. 6hrs/week roughly.
It’s day one of schooling from home for two of our kids, I think it’s going quite well but the mrs is losing it, and I’m feeling quite tired already.
Interested by the Run Less Run Faster stuff. Is there an online ressource for that apart from the book?
They have an app for the “Run Less, Run Faster”. It will ask you some questions and plot out a schedule to your goal event. It has a nominal one time fee that is possibly cheaper than the actual book.
Yeah the app is cheaper than the book but personally Inthink anyone should read the book - it’s only £6 or £7 on Kindle iirc, and well worth the read.
Imo lots of people modify RLRF without understanding that theres more to it than 3 runs per week, and end up failing or in injury.
Run less, run faster is tough. Did it once and beat me up and difficult to hit the paces. Good luck and hope it works for you.
I am a Pfitz person now but still modify that slightly when doing or training for an actual event.
It’s worked really well so far, no niggles, and I’ve set PBs at a variety of distances including half marathon :grinning: Shame my marathon was cancelled otherwise I’d have a full review to give :grimacing:
I don’t know how you approached it, but even on the RLRF Facebook group few people are adhering to the protocols. Most skip the prerequisite 3 month mileage, skip the cross training, run more than the key runs, don’t adhere to the paces on the key runs, and don’t do strength work…which is why I think reading the book was a revelation for me.
Thats awesome to hear. For me I need more volume at slightly slower paces to get faster. Maybe when did that program (5+ years ago) i more than likely put my targets way to fast. I still have the book.
That’s what I did about three four years ago, I got a free copy of the half plan off the net and ran as hard as I could for the intervals…was injured in about six weeks :slight_smile:
I’m sure it’s still not for everyone but I think it’s worth revisiting.:+1:
I really liked this part of the book. It frames your progress as a bigger project than just running.
FWIW a few years ago I tried the Nike Run Club app that has a coach function for 3-4 runs a week. I was progressing really well with it and it adapts the plan and paces to how you feel/do. Was never this tired before from only running :slight_smile:
Has anyone tried modifying the triathlon plans for be 2 weeks of build with 1 week of recovery? I’m just finishing HDBaseLV and just failed at Dade -1 (even after i adjusted to 110%).
The second half of base i find hard and V02 max is a particular weakness.
Also not sure how i should modify the VO2 work as i’m looking at those workouts (long and high pulls 115 to 120%).
Looking for some advice on how to take things. Send help. Lolllll
@JoeX @Nate_Pearson @chad @Jonathan
Go to calendar and after the 2 weeks just push the 3rd week and insert in your recovery rides. Then rinse, repeat moving forward. After you get the recovery week in there you can copy it and put in a future blank week to save you some time.
Hope that makes sense.
So
Week 1
Week 2
Week 4
Week 3
Week 5
Week 4
Week 6
Week 7
Week 8
Thoughts on how to do modify the V02 max work given my difficulty with those workout or just give them a go.
Something like this. It will make the plan slightly longer but it could work for you. Add the plan on the calendar and then:
Week 1
Week 2
Push week 3 and add in your recover ride week
Week 3
Week 4
Push week 5 and copy prior recovery weeks rides
Week 5
Week 6
Push week 7 and copy prior recovery weeks rides
Week 6
Week 7
Push week 8 and copy prior recovery weeks rides
Week 8
For vo2 max i would just lower the intensity a little if needed to make it more manageable.
I think consensus is that vo2max power can vary a lot between individuals and the FTP as determined by the ramp test can be off the mark for some. For vo2 try adjusting so that you can complete your workout. It is better to complete an entire set at 110% than to quit 120% half way through.
How hard should these be? Depends on fitness and genetics, almost throwing up (but getting through) is a good anchor point.
A failed workout - and we’ll set aside what failure is for now - is no big thing. HD Base LV has something like 90 workouts (SBR), if you didn’t start even start Dade -1 you’ve got a lot of work in :smiley:
A session where you’ve struggled or missed intervals can be from a stressful week (I don’t know anyone globally chilled out right now), lack of sleep, a skipped meal…lots of things…or just not enough space between workouts.
I would look at everything, and give myself some leeway before drawing conclusions. :slight_smile:
I think @ericallenboyd has it for shuffling the weeks about :+1:
@Ripi
+1
As you’ve said vo2 tends to be a problem, I’d rule out all the other factors mentioned in my last post before committing, but dialling down intensity to 95% I believe is acceptable.
In my experience, so just me, the only time I repeatedly failed vo2 workouts and was fine with everything else was when I moved from Mid to High Volume for Build and burned myself out. But it was tragic to watch (if I’d had an audience), not just a failed workout.
Thank you!
Don’t have any “recovery weeks” for reference for half distance? Do you have any recommendations of what that week should look like?
