Tacx Neo not in ERG-mode
Thank you, Chad. This makes a lot of sense and definitely may explain what I’m experiencing. I may have to just drop off ERG when doing things like Taylor -2 or other VO2 Max type short efforts.
But I still dont understand why? If I read Chad’s comment correctly, he recommends to keep steady state. How does it differ in resistance mode? At the end, steady cadence means steady power plus steady HR. I am confused and still could not understand what resistance mode will bring extra? :shushing_face:
When you switch to Resistance mode, you are effectively riding a smart trainer acting as a dumb trainer.
The assumption (that I did not state) is that you will need to shift and adjust cadence like a regular trainer (and not like using ERG on a smart trainer).
That allows the rider to make changes in power to match target power faster, via shifting and cadence adjustments, that a smart trainer can’t match.
So it’s common for some riders to use Resistance or Standard mode in TR, for the short and sharp types of intervals.
Does that make sense?
