Steady-state maxed for 60-minutes; AI wants 90-min weekday workouts the next two weeks
I just had two weeks of vacation and had a big FTP drop. Now, I’m back at it with a new plan set to a moderate approach, and the next two weeks, my calendar has overridden my 60-minute T-Th workouts with 90-minute workouts. I don’t think I have time for that.
It seems like better options would be either to do VO2 max or Threshold workouts for these two weeks (basically advance the schedule) or to readjust my FTP–it seems I didn’t lose as much fitness as the AI thinks.
I’m hoping for your input about the best options. I know I can turn off the ride extension, but I don’t really want to ride 55 minutes straight at steady-state. :slight_smile:
My opinion: 60 minutes isn’t enough for a productive Sweet Spot workout unless you’re just starting out at a new FTP. Either ride longer, or move up to a shorter Threshold workout instead of Sweet Spot.
Both of the 60-minute workouts we’d replace those longer ones with are good, in my opinion.
Also, if you think you’re fitter than TR says, they shouldn’t be too hard.
Manually bumping up your FTP could give you workouts with shorter intervals, but that’s not the route I’d go, personally. :man_shrugging:
Another option would be to see what the “shorter” Workout Alternates for those two are. You might get an option that’s less sustained.
Not sure why TR goes right from 60 to 90, at a 50% increase in training time when there are a good amount of 75min workouts as well. Maybe that would work for your schedule a bit better? I see in those 90min versions there are pretty good recovery block lengths… could likely get in a similar amount of Work, with just a bit shorter recoveries. (might need lower in SS range tho).
Alternatively can manually make the 60min SS a bit harder with ++% here and there to make it a bit like a over-under workout (but make the over right near FTP).
I guess my post was really about two concerns. You all have some decent ideas about the first (what do I do about this?)
But my remaining concern is that it’s odd to me that the AI plan builder would put itself in this position. It’s strange to jump from 60 minutes to 90 minutes, and it’s stranger still to promote this progression one week into a new block. This approach also seems very aggressive when I have my approach set to Moderate.
My guess here is that this is a result of that time off and FTP drop.
As you said, maybe your FTP didn’t actually drop that much, and now we think you’re ready for harder workouts that we can’t prescribe in the allotted time in some zones, which is why we’re suggesting adding more time to those workouts.
Maybe try manually bumping up your FTP by ~8 watts to see how that affects what we’re prescribing..
I took your advice, and today’s Eichorn+1 felt right to me. My heart rate ended up on the high side for sweet spot, but I think that’s largely hormonal. I feel good. Thanks!
Nice!
I’m glad I could help.
Let me know how things go moving forward. :+1:
