Everybody talking about smooth power. Show me those smooth power files when you are riding outside. The idea of a indoor trainer for me is to train for outside races. Who cares if the power is jumpy because power is jumpy outside when riding and racing as well.
Follow-up question: can you install pedals at 170 length spot via hex wrench? That is, does installing / removing pedals require the pedals to work with a pedal wrench? Iām asking because I use Time pedals, and for install / removal they are hex wrench only.
You can rotate the crank to get an allen key in there, but itās a major pain. It can work, itāll just take 1000 little turns.
Thanks ![]()
I installed mine at 170ā¦pain in the @$$ for sure.
Interested I in any updated thoughts and opinions users have after spending some more time on the bike and after some software updates
Give me a couple of weeks, and I will add in a review. Mine comes Wednesday ![]()
The comparison will be to a Gen1 (gen 0.5 as it predates the official gen1 release date) Wahoo Kickr / InsideRide Kickr E-Flex combo
I continue to really like my SB20, and am completely satisfied with my purchase. I realized the other day that my fit wasnāt quite right, either Iām tightening up over the winter months, or just other changes in my riding form, and the adjustability of this bike is so good I was able to pretty quickly dial in a better fit. And it remains rock solid and quiet, just a quality piece of hardware.
well i personally adore my SB20. for me itās the best smart trainer on the market hands down
Any advice re zero reset?
Using the stages app, sometimes it will zero reset successfully and sometimes it wonāt, even though Iām doing the same thing each time.
Anyone else have this?
How do people handle workouts like Spanish Needle with the SB20? Iāve read a lot about the intervals being so short that the ERG mode doesnāt react quick enough to settle for this type of interval.
My SB20 is coming today and Iām moving from a KICKR.
The KICKR ālooksā like it responds quickly but I now wonder whether thatās down to smoothing the KICKR firmware applies and itās actually struggling too, or whether itās down to the size of the flywheel being much larger on the Stages and taking time to ramp up?
If only Stages could implement a sliding scale in the Link app so that you could pick how much smoothing or response time to ERG changes you wanted!
I donāt have experience with the bike (still contemplating a purchase) and quite what you are looking for, but what I was thinking would be a good option is the customize the ādream driveā for short hard sprints like this. You could figure out what gear works best for the recovery and what works best for the interval and with a touch of a button switch between them.
For me I think itās entirely a smoothing thing from Kickr that creates a false sense of precision there - I also went from Kickr to SB20, and I find the transitions on the SB20 are just as smooth, even if the graph says otherwise. I definitely feel like it ramps up quickly and I get the work in.
Maybe change the power from 3s to 1s for workouts like that? Havenāt tried, just a speculation that might make it look betterā¦
Hey, thanks for starting this thread. Iām interesting for recommendations for setting this up? We are getting ours on Thursday. I know that the power smoothing / flywheel size presents a bit of a delay, but I actually experience a delay on my Kickr Core now. When I have sprints, it takes ~5 seconds for the ERG to catch up so I am always about ~15 watts below the average when I wrap the 30 second sprint.
The huge flywheel, easily twice the mass or more of the competition, creates a realistic feel, great inertia, doesnāt slow down so dramatically if you stop pedaling, and has a couple of other benefits. But weāre talking about MASS, and an increase will bring both benefits and costs. The cost is that changes in power take longer to result in changes to the flywheelās rotation, especially for something like ERG mode.
What Iāve learned to do is something already suggested above. For very short intervals, take it off ERG mode and figure out how many gears you have to shift for your intervals and then your recoveries. Use the app to set up gearing thatās convenient for you, such that you only have to click the shifter button once or twice, and then use resistance mode and shifting to do your intervals.
The bikeās response, IMHO, is great: because youāre changing the magnetic resistance by shifting, that happens much more quickly.
Iāve had mine for a couple of weeks now, and both the wife and I like it a lot. For reference, Iām coming from a gen1 (gen0.5 as I got it before the official gen1 release date) Kickr + InsideRide E-flex.
The Stage Bike is an immovable tank, especially as mine is on the ground level on a wood floor over concrete slab. At first the bike was uncomfortable, but my wife got a gel seat cover, and I hesitate to admit Iām using it and it makes a massive difference in comfort. Food for thought if it feels uncomfortable when you first ride it. Second pearl of wisdom when in Erg mode: only connect the Stages Bike, not the pedals, and disable powermatch. Powermatch isnāt supposed to be on, and it makes the ride feel pretty horrible. I learned this the hard way after the first couple of rides felt pretty bad.
I havenāt used it yet for short intervals, but I agree with agingcannonās advice - set up the gearing so that you can use the āfront shifterā to be able to jump from recovery to short interval power in one click. My recommendation would be to use dream drive with 50 gears - equivalent to a 1x setup with a 55 front, and 11-50 cassette with 50 sprockets. You can then customize how many sprockets the āfrontā shifter shifts. This gives you the ability to make large gear changes with the āfrontā shifter, and small adjustments with the ārearā shifter.
Iāve been quite polar on mine but now resolved issues in summary itās a great piece of kit
Had some early software issues early 2020 but now seem fine
Erg mode was a bit slow to adjust resistance on the short intervals but now I donāt use it for those I have dream mode and my left is 3 gears and right 1 gear and I therefore get a good jump for the vo2 and ability to get smooth adjustments which Is great
My key issue was the flywheel. I had the noisy issue and gen 1 which needed replacing so it got unusable in autumn and had to wait until jan to get a new wheel. Now I have the new wheel itās much smoother, much quieter and this is the wheel that ships with new bikes. Whilst this meant I didnāt use my bike for months I fortunately had my kickr and Stages did give very good service in responses, and majority of delays in the wheel were down to COVID shipping and logistics. I also got some premium stages link software to try so Stages did do their best customer service possible in the circumstances
The bike is built like a tank being best part of 70 kgs. Easy to dial in position. Love the holders for iPads etc and the charging. The bottle cages are quite low angle so if you have bottles that leak a bit make sure they are tight if full
Agree the saddle is a nice shape and good quality but I will be changing this but thatās just personal preference
In operation the bike is super smooth and I can really let loose and not worry about frames and or jumping off the kickr which I did with a quick release. Itās great for sprints
Noise is much lower than the chain noise on the kickr also less messy and no more
Oil on the carpet
Due to its sturdiness it is rigid so I am thinking of a rocker plate as I do long workouts indoors
Despite my teething issues on the wheel itās a great piece of kit and would recommend it.
I think it is a great bit of kit when itās working, but when itās not, itās hard to find direct help in the UK. I end up relying on the kindness of strangers on FB.
Iām not particularly tech savvy, but I donāt think I should have to source a way to get into dev. mode to change PCB orientation due to the effects of a firmware update, with no direct support available until they answer the ticket in 6 days time.
So I would advise people in the UK not to buy an SB20 unless they have a career in tech/ programming industry.
Currently my left crank has a serial number of 0 and it is not possible to change it, even in dev mode. Currently the bike is āworkingā but is not registering power in TR/ zwift.
Iām going to try a work out just using RPE today. As Iām recovering from an op, I canāt run yet and Iām not quite ready for MTB outdoors, so itās super frustrating.
If you contact them via saddleback (the UK disty) youāll get an overnight response⦠not sure if youāve tried that route
Thanks for the heads up
I emailed Saddleback Friday and expect a response on Monday. My son used his iPhone (Iām android) to roll back the firmware update and reinstall it. It seems to have found a serial number over night. I managed to train today, despite a drop out and restart and having to open the stages link app so the gears would work half way through.
