I’ve been using TR for two years now. Overall very happy but have noticed a trend that I’m wondering if it might be a problem.
I’m 61 yrs old and been riding a relatively short 4 yrs. No racing but I do enjoy events, long destination rides and some fast group rides. TR has my FTP 240-245 which I know is higher than it should be. I’ve done a lot of long steady hill climbs and my most recent has been 231 watts for 30+ min. Maybe I could have done a few more min but that’s it. My highest 60 min effort has been 210.
The problem is whenever i do a scheduled VO2 max workout, they are usually rated as “hard” and occasionally “very hard” if it’s up to level 6-7. But when I do a threshold workout level 3-4 it’s almost always very hard. Basically the longer efforts are a struggle and the shorter higher watt efforts are not. But TR seems to weigh the “easier” VO2 workouts towards a higher ftp.
Would it make sense to keep my FTP lower? Around 230. I’m hoping TR will adjust the interval length of the workouts instead of constantly increasing the watts.
I am 66. I find Tr AIFTP tends to run on the higher side at times. I have lowered my FTP in the past but now find I just need to learn to adjust the workout to what I can do. Is age a factor here, dont know but I have been with TR for 11 years and just find it easier to adapt a workoout to one I can do. Yes you dont know what you can do until you try but the mental game kills me with threshold workouts.
I do well with VO2 workouts as I can really sort out where I should be on them. The short breaks let me survive. Threshold workouts are a different story as doing 9-12 minute intervals of over unders becomes a different level of effort. I am not always in the mindset for that level of discomfort as quickly as the software wants me.
The levels you quote are fine. The threshold at 3-4 for me are hard. I just did a VO2 at 8 which I thought was an overreach but I completed the workout.
What I notice for myself is my VO2 workouts push the power curve up and the threshold tries to get me to do a workout to sustain that power. It isnt always possible despite the fact the VO2 power chart shows I did it. So look at at your power or NP of your intended workout. Either chart. I wouldnt be surprised if that is what you see.
So you are trying to do a steady state workout at the power you achieved with your VO2 workout. I cant get there as quickly as the program says I can. I find I need to take a couple of workouts to get to the one it wants me to do. I just find doing a slightly lower threshold workout works better in the long run. I dont push threshold workouts up at the same pace that I can push other workouts up.
The other item that you can do is adjust your intensity down by say 2% and see if that lets you get through the workout better. No need to kill ourself at this age. I know my own weakness is muscular endurance. Whether I do the whole workout at 100% or do the last set at 98% my legs still feel the same after. I still find I improve over time so in the long run I just find I end up in a better mental space for miserable threshold workouts. See what works for you.
This is the same problem I had. The power curve wanted to take average watts from 20 minutes of VO2 on/off and extrapolate that to what I can do over the course of multiple long threshold intervals, and it was a recipe for failure.
You can absolutely discuss my training here or share anything on my calendar. I try to be very accurate in my outdoor ride description. My Z2 rides are true Z2 as you’ll notice on my power profile. If I pushed on a group ride they are usually marked as Z3 or 4 and I treat that as a workout so I can manage my fatigue.
Are you using different power meters depending on if you’re riding inside or outside? If so, have you ever compared them to see if their is a discrepancy?
It seems like your indoor workouts feel harder than your outside rides..
Based on your last couple of indoor rides, I’d say you could probably drop your FTP by about 5 watts, but you’ve had some really strong outdoor performances in the last few weeks…
I’ve checked my power meter and it’s accurate. There’s definitely a mental aspect playing against me on the trainer when I’m staring at the graph and timer. Seems so much harder and the time drags on. When I’m outdoors it’s mentally easier and my HR even gets higher. But even with the better performance outdoors, I’m still nowhere near the FTP suggested.
Tonight I just did a sweet spot workout that felt like threshold. I marked as very hard and TR already started adjusting my FTP prediction down. This is the usual trend. The workouts early in the plan are sweet spot and threshold. I’ll struggle and TR will start to lower. Then when the VO2 and anaerobic workouts start, it will ratchet me back up again. Maybe I just won’t accept the increases?
I think it’s worth considering that you may simply have a relatively strong anaerobic capacity compared to your sustained aerobic power. I find myself often in the same boat. Some riders can handle shorter efforts way above FTP but struggle with longer efforts closer to threshold. That doesn’t necessarily mean your FTP should be higher. If your threshold workouts are consistently very hard while your VO2 max workouts feel manageable, I think that’s worth paying attention to. Personally, I’d be inclined to try lowering your FTP to around 230 and see whether that makes your threshold workouts more productive. The goal isn’t to have the highest FTP number possible. It’s to have training targets that produce the adaptations you’re looking for. One other consideration is that VO2 max workouts are highly individual. Percentage of FTP isn’t always a great predictor of the power someone needs to reach VO2 max, so it’s entirely possible that your ideal targets for VO2 max and threshold work don’t scale together perfectly.
I’d focus more on getting yourself in a place where you’re getting productive threshold and sweet spot workouts. If you end up needing higher-level anaerobic workouts with that FTP, that’s totally fine.
It’s not uncommon at all for athletes to have some separation in levels between sweet spot / threshold and anaerobic workouts.
I’d try dropping your FTP by ~5 watts to see how those sustained workouts start to feel.
I intentionally back my AI FTP in the 2026 software updated world off a little to enable my Threshold work to progress into progression levels in the 4-5s range. The purpose of this is to have workouts with a higher density of Threshold work as a percentage of the total workout time. Once I have that all under control I’ll raise FTP, if warranted, but not at the expense of dropping progression levels below 4.
I’d love to hear your opinion as I have a similar-but-different issue. Towards the end of last season I was relatively comfortable in Tempo and Sweetspot (level 6/7), ok in VO2Max (level 5/5.5) but massively struggling on anything in the Threshold zone, dreading any workout even at level 3. This has really been puzzling me for a while.
Also, I went outdoor and when pushing for a PB on a 40min climb I managed to “only” average 330W vs AI FTP of 348W at the time.
Now, I understand the point of tweaking the AI FTP to account for different physiologies. However, having AI FTP and thus not having to test and/or guess FTP was/is a massive selling point of TR for me as I hate tests. It has honestly put me off a little, even after posting various PRs this season, as I got to August completely cooked and I think a FTP that’s too high is partially to blame.
Feel free to take a look at my account. I have not used it in the last month due to an injury and some other life things (moving to a new country soon!) but the two years before that were done following TR quite religiously.
That’s another reason I was thinking of lowering it. Otherwise TR will start scheduling shorter threshold intervals like 4x6’s when I think I really need the longer 10 or 12 min intervals.
I’ve also manually adjusted the Threshold intervals to harder ones. In my last training block for Gravel Worlds TR had me at a 50%+ prediction of failure on Threshold intervals which I would complete at the expected difficulty rating (Hard) without disrupting the rest of my training.
To be fair to TR, I’ve prepared for other the same event both before and after the software update in February simply following the prescribed workouts and achieved very similar event results, albeit with adjustments to volume to manage overall TSS and fatigue in the week. So with:
lower PL I added more volume; and
with higher PL I reduced volume or if I didn’t reduce volume then ended up having to fairly frequently skip one of my two main interval sessions per week.
Amen to this. Extending time in zone I think would benefit lots of cyclists more but it’s hard work, kind of boring and doesn’t lend itself to marketing quite so well.
