Of course you are right. My feedback is irrelevant. Come on. Not everyone finds them the same
This probably comes down to my frequent comment that it is problematic that we have a workout power zone named VO2 Max and also have a fitness measure named VO2 Max. People arguing about “VO2 Max” are often not noticing that one person is talking about the first while the other person is talking about the 2nd.
It’s reasonable that you may feel a workout done in the VO2 zone isn’t as hard as another workout done in the Threshold zone. OTH, if you’re doing a workout meant to improve your VO2 Max, that is likely going to feel harder than a zone 4 workout.
As Pbase said here this is probably the confusion.
If you are doing workouts to improve your vo2 max (and not just ones labeled vo2 max due to them being between 106-120%) they will feel harder than a threshold workout.
I understand what your saying but this has never been how I find the workouts. Threshold are my struggle. Doesn’t matter if the VO2 should feel harder they don’t. Don’t know why you can’t accept my opinion on what I feel is harder. This is obviously not how you find them. Doesn’t really matter.
I am done on this.
I think the confusion is the same as what was said up thread.
If they dont feel harder that FTP you either have an over estimated FTP or are not going hard enough to hit and maintain vo2 max.
There is quite a large range in what people are capable of >FTP, and if you have an especially high anaerobic capacity then the typical range of 106-120% wont be enough to actually hit vo2 max.
Or the intervals are not long enough, or the rest intervals are too long if doing shorter intervals or you are not doing enough intervals.
Any effort above threshold will eventually elicit VO2 max. It is a question of time. How long you need is individual.
What happens if I do a TR FTP test? Does TR adjust workout zones based on that result?
If you perform an FTP test of some sort, you can use that figure for your training. Physical testing does come with its own set of issues, though, so what’s most important is ensuring that your workouts feel appropriate regardless of how you’re landing on your FTP.
Thanks Eddie - can you answer a question directly please?
Is FTP from a ramp/20 minute test a year ago the same as FTP now in TR?
I see lots of people saying ‘my ftp is wrong’ or ‘I did a test’ but these FTPs don’t match what TR is now using in my (basic) understanding.
Hey,
Your case is a bit interesting. It’s pretty much exclusively threshold workouts that you’re struggling with even though you’re setting all-time power PRs during relatively high sweet spot workouts.
Maybe those are fatiguing you before your threshold days?
Regardless, I don’t think it’s a bad thing for those workouts to feel very hard sometimes, as long as they’re remaining productive and at a good level.
Are you still doing TR workouts? Either way, make sure you’re filling in those RPE surveys!
I would like to think that with your ratings, that it would learn you have a strong anaerobic component enabling you to do your vo2max workouts without getting wrecked. Similar from what I know from podcasts of Pete/Thor and Jonathan. Shorter punchy stuff they could go hard and keep doing it! In the past it was often discussed that doing vo2/anaerobic stuff needed to be by feel or adjusted until you got that feeling of a bit of HELL… some people that is 5x2’ at 115%… other riders might need 120+% to elicit the mostly fast component of vo2 for a shorter vo2max interval. (or shorten recovery).
So i would hope - that over time it would ramp up your vo2 work until you were skirting the very hard / max / hard balance on your workouts. Or you can adjust intensity after a rep or two to dial in the effort. repeating a workout week over week can sure help. Sure sounds like the AI hasn’t caught up… because i’m not sure if you are getting a solid vo2max training adaption if it feels pretty good
— you’ll want to turn it up until it feels very NOT good for ‘gains’ , like in the gym… if your final reps of each set are normal pace and face isn’t strained… they shouldn’t be the final reps of the set.
should get a little ugly
Eventually i would hope it would show up as a high vo2 progression level and a lower threshold with a similar amount of time in each zone.
Maybe with people doing perfectly space 3 workouts a week, pretty consistent fatigue/recovery cycle, this doesn’t happen as much to others as it does me…
For me on a masters Tu/Thur hard workout cycle… EVERY Thur workout is definitely effected by Tuesdays workout, could easily make me think “i’m good (or bad)” at a certain type of workout based on what is 1st or 2nd in the week!
My setup isnt ideal (TR even warns on setup that way), but I like the longer weekend runs/rides with free time (so then can’t do hard intervals well on Monday), and can’t dedicate a Friday to a hard workout (sometimes run club friday AM, often Fri evening Date or events).
I think you are referring to the “great FTP recalibration” event in January 2026 with the launch of TR AI. This is where we switched from the well-known but highly-debated industry “definition” of FTP to the new/different/better/worse TR “definition” of FTP, and countless forum threads.
Well, I got recalibrated down by 5% which was annoying to the say the least. That’s maybe a year’s worth of gains somehow absorbed into a new different (better?) scale. I tried for a while to keep two sets of books, but I could never get the math to math, and just gave up. Now my TR detected FTP seems to have somehow converged back to my measured FTP to within measurable accuracy. I don’t know what changed or how to explain it, but have basically decided to not worry about it.
I do wonder if knowing what the number is “supposed to be” leads to an effort that delivers that number but no more. A ramp test, for example, comes down to fortitude and motivation in the last minute and it’s ultimately only the last minute that counts. For every additional 4 more seconds you can hold, your FTP will go up by exactly 1W. A 20 minute test comes down to knowing the answer before you start so that you can pace it right.
If you think your FTP is set wrong, and you are sufficiently motivated, use a ramp test or a 20 minute test following all best-known practices, use that to set your FTP, and then let TR AI worry about the details. If the workouts are too easy/hard it will adapt and get you in the right zone.
I’m not a fan of this argument. Did we argue about FTP a little? Sure. But was it just a random number that no one had any idea how long they were supposed to be able to hold it and there was no way to compare it to our past numbers or to other cyclists? Absolutely not. You may have gotten yours from a 20 min test, and I may have gotten mine from a 60, but either way, we knew what it meant. There was data behind it, and we could explain how it was factored.
Fair enough, let me amend to: “the well-known but sometimes debated industry definition of FTP”.
Of course, if I did try to actually write down a definition of FTP we would instantly start a debate. ![]()
Thanks. I am asking if doing an official TR FTP test on the TR app would result in the subsequent workouts using the results of that test for training zones.
Thanks for your response.
I have been using TR since 2015 so I have seen all the ways and adapted to the latest system.
The new AI acknowledges that I do well with VO2. It thinks nothing of jumping me 3 levels to progress. The progress is always quick to move me up for VO2.
The VO2 workout in the last month before my FTP jump was Clouds rest +5. Its 30/15s at 130%. It was marked as moderate. Progression did end as I had an bump in FTP and then off to non VO2 workouts for now.
Threshold is a different story. I find them hard. Always have. Always a struggle. Am I at the right level. Likely as they are low 3/4 but I do think not getting to push into higher workout levels play a role here in long term adaptation. I know my weakness is steady state rides. My muscles just dont do as well on the long intervals. Need more of them. Short duration intervals with breaks let me recover my legs and I do better.
Thanks for getting back to me as well!
Yes and I am definitely very happy with PRs. But I was wondering if maybe what I was doing during SSP was really Threshold-in-disguise due to the too high FTP, effectively doing Threshold work 3/week for months, that led me to being cooked in the end.
Fatigue is an interesting take, but thinking about it I don’t think that is actually the case. Due to time availability I have sometimes switched workouts around and other sessions were never impacted that much. Or, to put it in another way, with other workouts it has happened that I felt fatigued but I could clearly trace it back to some previous rides and link them to that.
I have been filling the surveys quite religiously, also trying to stick to the TR definition of Easy/Moderate/etc as much a possible, the FAQ page on the surveys is in my favourites ![]()
And no, due to a number of reasons I have not in November/December this year but I will most likely restart in the new year.
You’re asked if you want to accept the results once the test ends. ![]()
You’re knocking out workouts in zones above threshold without issues too, though..
If things are really consistently too hard, you could definitely try dropping your FTP down to see if that helps. Your other workouts will compensate for the change.
Let me know if you give that a shot and how it goes. ![]()
