Shimano Dura Ace 9200 [speculation]
Yep, I saw that already. I got too excited and overlooked it being old news.
Two things about that: Pros also don‘t use the 11-tooth cog on the flats either, nor do they use the 12-tooth cog. Just have a look at the speeds you can reach with either, pros choose chain rings so that their chain line is as straight as possible and gears that are as large as possible when they are cruising. They want to maximize efficiency in the gears they use the most. But I reckon the extra gear they have on a SRAM-equipped bike will still be helpful when going downhill, and the fact that it has 10 teeth won‘t matter much.
The second thing is that most people are not pros, and what is best for pros is often detrimental for ordinary or even very fit riders. The 10-tooth cog is usually only used when you are going downhill, and then I doubt the loss of efficiency matters much for the average rider. What you gain is much larger range, which is something every rider can appreciate. IMHO road bikes are ridiculously overgeared for most riders. I‘m reasonably fit and my lowest gear is a 40:36 = 1.17, and I sometimes have to grind even though I put out a decent amount of power when climbing some hills (think 300–400 W). On the top end (42:10 = 4.2), I can pedal until 60–65 km/h, which is plenty on public roads and all races I have participated in.
IMHO Shimano‘s marketing department has overdone it, leaks have trickled out for months and it seemed designed to stave off design wins of bike makers building more bikes with SRAM groupsets. “We will have 12 speed groupsets soon, too, we promise!”
I‘m not sure what we can expect from Shimano: the ergonomics seem largely unchanged, which is great if you like Shimano Di2 shift/brake levers and bad if you don‘t. I reckon they will include Bluetooth connectivity by default, i. e. they‘ll join the ranks of everyone else. They‘ll have a 12th cog Campag style, so their 11-32 12-speed cassette will be geared like their 11-28 11-speed cassette, just with an extra cog. I reckon they‘ll feature an 11-30 or 11-29 for people who want more closely spaced gearing and don‘t need climbing gears. Lastly, it seems that the crank features a more symmetric crank arm design, which bodes well for power meters. I hope they‘ll have a better story when it comes to power meters, though, because SRAM has been eating their lunch here, the Quark DZero is hard to beat as a crank-based power meter. (Or you could go to Assioma et al. for an equally good pedal-based power meter.)
What I expect Shimano to not have is e. g. a 1x option, flexibility when it comes to gravel/all terrain drop bar bikes, and I am not sure they can deliver on the power meter side either. SRAM has released a very affordable Rival AXS power meter that is as cheap as any left crank arm power meter (e. g. my old 4iiii or a Stages), and their Quark DZero works for their Force 2x, 1x and Red 1x cranks (unless you insist to go with a SRAM Red aero 1x chainring).
So in a sense, I don‘t think we even need to read the reviews. It‘ll be a solid release, but we know what we can expect. People who prefer Shimano groupsets will be happy. People who want Shimano to be less conservative won‘t be. :slight_smile:
Uncensored Scott Plasma 6 Ultegra Di2 (2022)
With Ultegra cranks?
Although they looks a bit different
Shimano Ultegra branded wheels, that are 11/12s compatible.
Edit: apparently this is Disc brake only, while de DA wheels are allegedly offered in both variants.
Wait … are they releasing a new Ultegra 12 speeds electric shifting?
Wonder if Ultegra will be wired, then 105 becomes the current Ultegra (11 speed wired electric shifting) and da is the wireless thing…
That‘s the big question. Perhaps Shimano will also pivot its higher-end groupsets to electronic-only just like SRAM did. From a financial point of view (for Shimano, not necessarily for us athletes) that certainly makes sense.
Are they both the same semi-wireless? i.e wired to the battery?
Not a triathlete, so fugly :stuck_out_tongue_winking_eye:
[quote=“OreoCookie, post:236, topic:54221, full:true”]
That‘s the big question. Perhaps Shimano will also pivot its higher-end groupsets to electronic-only just like SRAM did. [/quote]
My understanding is that there is not a huge demand for Dura Ace mechanical. Most people wanting that precision and weight (and are prepared to pay for it) also want di2.
Still solid demand for Ultegra mechanical, and will be for many years to come I am sure.
Likely, there is:
https://www.cube.eu/2022/bikes/road/road-race/agree/cube-agree-c62-race-carbonnblack/
There´s no proof that this Cube Agree will have electronic shifting - could also be mech Ultegra - look at the price point.
The reason for the demand is price.
There is a steep price increase between Ultegra di2 and Ultegra mechanical.
Shimano doesn’t care. As long as they sell what they have, which they will do, then they will probably move away from.mechanical.
My uneducated guess… This is the end of mechanical. The last mechanical will be Ultegra 11 and you will be able to get for years. Then they will make that mechanical 105 until it dies off eventually.
DA:
Ultegra:
The DA is €200 more expensive than SRAM Red AXS
The Ultegra is €200 more expensive than the SRAM Force AXS
Edit:
Even though I hope @Joelrivera and I are wrong, I‘m quite sure this is where it is going. I expect that Shimano will, just like SRAM, simply keep its mechanical 11-speed groupsets around, but if you want 12 speeds in the rear, you need to spring for an electronic groupset. In the future, I think the top-end mechanical groupset from Shimano will be 105. Apart from weight, 105 shifts as well as DuraAce mechanical, it is durable, and the differentiation between 105 and especially Ultegra is a challenge.
Currently, very few people are willing to go for mechanical DuraAce. For the essentially same price you can get Ultegra Di2 and in my observation most people go electronic then. I‘d probably do the same. So you have this staggered line-up and because bikes are getting more expensive “anyway”, why not charge customers more? Customers also easily understand the value proposition when they have the choice between mechanical and electronic.
DA - like the look if the chainrings.
Any new Infos about Powermeter(s) ?!
Can´t see any on the Screenshots…
Wouldn’t surprise me if they ditched mechanical, personally can’t think of a single person I know who has bought any mid or high end bike recently without some kind of electronic shifting and at $6k+, why would I not want to have infinitely better shifting? Makes no sense to keep mechanical around if the sole purpose is to satisfy the Luddite customer base who will find something to complain about on new bikes anyway, but does make sense to keep it around for lower priced bikes, much like how you can still buy stuff with 9s on the low end.
Personally think 12s electronic and 11s remains available as mechanical is a good move that will satisfy the biggest audience.
I’ve just bought a mid to high end bike with mechanical shifting :raised_hand:
That said, I always though that mechanical dura ace was a bit strange… I’d choose ultegra Di2 over that any day of the week.
