Shimano Dura Ace 9200 [speculation]
trickle down electronics to 105?
Will the current Ultegra Di2 will become the new 105s?
I don’t know the full details, but he did indicate a 105 Di2 was in the works…timing and spec unknown at this point.
Good thing I just bought an Ultegra Di2 bike…might as well throw it in the garbage heap :crazy_face:
How quickly does XTR follow the DA release?
No, don’t do that…bad for the environment. But yes, you need to unload it immediately.
I’ll DM you my address…send it to me and I will attend to the problem so you don’t have to worry about it.
(I’m very helpful like that. :stuck_out_tongue_winking_eye:)
I don’t think there’s any particular link between XTR and DA. 12 speed XTR came out in 2018.
Oh right. I assumed the updated DI2 would hopefully carry across to XTR DI2 (and hopefully trickle down to XT).
It will be useless indeed once new DI2 comes out. Might as well ride a penny farthing :joy:
German Tour Magazine wrote about the new Cube Bikes that where just launched and stated, that new Dura Ace Di2 AND Ultegra Di2 will be releaset on Sept 1st.
On Cube´s Website you can also see that NDA will be endet on Aug 31st
So - waiting has come to an end. New semi wireless Di2 will be introduced very shortly.
My guess: it won´t be available before April 2022 :wink:
New Bianchi 2022 models also indicate there will be 12s Dura ace di2 and Ultegra di2
The big unanswered question: did Shimano redesign the crank configuration so that dual side power meters (including its own) are actually accurate?
I doubt it, but I’m happy to be proven wrong.
The bigger question… will these parts be readily available and in stock?
:slight_smile:
That’s easy: they will be in 2024 :rofl:
Any indication of what the driver will be (for the cassette)? Would guess micro spline.
Edit - Tnx for replies. Missed that the gears were starting at 11t. If it ends up being HG driver and can get chainrings for current cranks, this will be going on my favorite frame.
Doubtful that they’re going to do that since there is no 10t and that’s basically the only reason XD/R and MS exist
Hardly hear anything from wheel manufacturers and no 10t on the new cassette so I think shimano likely will continue to use HG hub.
Given that the pros asked / pushed SRAM to produce pro only chainrings that obviated the need for the 10t cog, I would say there is zero chance Shimano will change to using the microspline/ XDR hub configuration.
The next Tour Magazin Issue will have a test of Shimano DA 9200 and they are apparently testing it already. This is the image in the Magazin:
The image itself isn’t new (see New Shimano Dura-Ace R9200 12-speed groupset spotted at the Baloise Belgium Tour - BikeRadar), but it’ll be good to see what they think of R9200 :).
Some of the larger retailers here in NL have done some rides with Shimano a few weeks ago, also testing the new stuff.
