Share your home mechanic mistakes and make me feel better about mine šŸ˜…
I’ve done that too, and got to that point before deciding that the hassle of sorting it was more painful than the annoyance of looking at it! 6 years later it’s still annoying me :grin:
..,. And of course that’s not the wheel I’ve crashed, or broken spokes on, or the one that cracked at various spoke holes - it’s been faultless!
You should be arrested.
They would have caught me too as I was stuck on the side of the road with a dropped chain!
I just did this 2 weeks ago :man_facepalming:
I have the same setup. Whenever I do things for the first time, on my bike, I examine things ad nauseum. I looked over my new rings and noticed that the inside is machined with a little seat for the torx bolt. Otherwise, it’s hard to notice.
My worst mistake was pushing back the Ultegra hydraulic brake pistons with a metal tool - - which I should throw away. Cracked, I totaled the calipers on the very first time I changed the pads.
I can’t tell you how many times I’ve put a new chain on in a rush and accidentally looped the chain through the outside of the derailleur cage….it actually shifts fine that way btw. It’s just a little louder :joy:
I did this on Monday. :sob:
What is the point of those tabs anyway? How is the RD working now? Makes me think of just cutting it off…
Yeah I don’t think I’m missing anything without the tab :man_shrugging:t2:
Think it’s just BIG BIKE keeping mechanics in a job
You can buy aftermarket pistons, they are arguably better than stock. Last set I bought were £20 which is cheaper than any caliper.
Not a home mechanic mistake but… I once picked up my bike from the shop and it felt disturbingly off-kilter. It turned out the cranks were one notch offset from 180Āŗ!
I was setting up some road wheels as tubeless a couple weeks ago. I was using the Reserve Fillmore valves for the first time. They don’t have removable valve cores so you just pour/squirt the sealant in rather than taking the valves out to fill the tire.
I filled up my tires to 80 psi to get them seated then attached a funnel to the valve to pour some sealant in. But it wouldn’t go in. I stood there semi-perplexed why it wasn’t going through the valves into the tires. Shook the the funnels a little bit to try and get it going. Still no luck. So I decided to poke a hex key through the sealant into the valve. Suddenly sealant goes shooting out of the funnel everywhere. Whelp, turns out my mistake was I forgot to deflate the tires before adding sealant.
Wont make that mistake again (probably)
Last night in a hurry I put a different front wheel on my MTB and not paying attention I put the wheel on backwards (yes, that means the rotor was not on the right side).
By pure luck when I put it in the fork the brake caliper sat right between (2) spokes and because I was not paying attention I just spun the wheel to hear some horrific sounds of the spokes blasting the side of the caliper and taking all the paint off.
Poor XTR caliper….
Most recently, was swapping to a medium cage derailleur to accommodate a bigger cassette, which would mean a longer chain. Sized and cut the new chain using the old cassette…:person_facepalming:
I have opened the bleed port on my sram axs shifter while attempting to replace the coin battery… twice :blush:
Both times I was cursing sram for making it so difficult to replace a battery… until I realised what I had done, then the cursing was redirected at myself.
First one that springs to mind for me is the first time I ever tried to bleed my own brakes.
At the time $30 a brake or whatever it was seemed too steep and I liked working on my own bikes so why not. Two sets of contaminated pads and rotors later I was out closer to $200 I think?
Of course when I got the bike back from the shop on my first ride out the pads fell out because they forgot to put the fixing pin back in…so…
More so though my issue is just trying to be kind of cheap here and there and that resulting in way more money spent in the long run. Most recent was this last winter I got my first road bike and thought I’d go all in setting it up fully internal hose routing. But it turns out I’m still the cheap guy who didn’t want to pay for a brake bleed so after well over $100 in mismatched Aliexpress parts, a full Ritchey setup which still didn’t fit, I finally caved a bought the FSA stuff I should’ve bought from the jump. Of course even that required a wonky 3D printed part for my bike so it doesn’t look quite right.
If I had just gone for the Bontrager stuff that would be made for my bike from the jump probably would’ve saved a couple hundred bucks :man_facepalming:t2:
Oooof I have learned this the hard way about many things!!
Arguable if this one is actually my mistake, but: Brand new S Works Epic 8 Frame (2024 Stock.) Apparently Specialized lists different torque values in two different places for the Shock Extension, which I didn’t realize until I’d stripped the threads in a $230 carbon part. I’m not convinced it wasn’t torqued wrong on initial assembly either, as it broke real, real hard when I was taking off the shock.
With my bike out of condition - quickest resolution was just order the damn part instead of going to a dealer to argue about a warranty replacement.
You’d think I would’ve learned by now too. But there’s just so much shiny cheap bike stuff out there! Admittedly the tariff situation in the US has slowed me down significantly lol
We had a friend who got a brand new Rudy gravel fork on a killer deal for his new build. He measured the headset and spacers he would need to get the proper stack height and cut the steerer–but forgot to include the height of the stem :grimacing:. It’s slammed with an upright stem on it now…
Waxed my chain for unbound, replaced it on my bike and struggled the whole race with it making noise/coming off when I shifted up hills(sorta important at that race). came home and discovered i had it over the tab on the tension pulley.
