Glad to hear it. If you tap the gear icon at the top, and then check out your Profile page you should see some red text showing something about your trial ending soon. Tap the red text. That takes you to the subscription page.
If you forget, the app will start to remind you once you’re half way done with your trial. (in-app reminders only. Notifications are not my favorite so we’ve avoided any of that so far.)
If anyone is experiencing any issues with their iOS subscription, let me know. We’ve had a small number of iOS users report that the subscription isn’t “sticking.” I can have the engineering team fix it quickly for you. Just let me know.
Thank you for letting us know! Please update your app to v1.0.44 and it may fix this. If you were seeing the “test card” messaging, we believe 1.0.44 fixes that for everyone.
On your phone, go toiOS or Android store and tap Update.
There is still one lingering subscription issue we’re dealing with and if you’re being blocked from using your app because of it, please email support@saturdaymorning.fit. I’ll get you taken care of immediately in our back-end.
Regardless, reach out wherever you find me online or in email, and shout at me until I’ve fixed your issue. There is no excuse for taking anyone’s money and not providing the service as promised or better!
Also, we’ll be adding a native option for malto within the app in the future too. Just figuring out how to present the options for ratios of carb sources to folks.
You’re right, this should be fixed, but a better solution in the short term would be to put something like 60g Carbs and 1mg Sodium as the serving and then use percentages of a serving.
Just FYI - the brand of Malto that I use does include sodium, so you might want to double check.
@JacksonLee, I had no issue adding in a Malto custom product at 0mg sodium into the app. Perhaps it’s because you only added 1g of carbs which might be causing the error you see??
For my custom product, i added 60g carbs, which is what one serving of the malto product I use is.
No problems. I really like the app! After using it for a week I have found my performance in harder sessions has improved quite noticeably. I will definitely be continuing my subscription beyond the free trial.
@Dr_Alex_Harrison. Does the app factor in multiple workouts a day. Ie. I commute to work and home 90 min each way. And sometimes jog for 45 min at lunch. Will the app factor this in or does it see every workout individually? Also should i care about this and always fuel every workout the same regardless of what came before or whats next?
Right now, it does single sessions and ‘combined’ (brick, triathlon, duathlon, swim-bike etc) sessions only. It will handle 2- and 3- and 4-a-day scenarios in the future. Right now, you can do multi-session days just fine, but it does see each session only individually right now.
If you’re doing multi-session days, please select “balanced” or higher no the performance vs. satiety/whole-food setting.
This is the exact same request I came here to suggest. Allow users to specify bottle size, generate a per bottle amount, and perhaps say consume 1, 1.5 bottles/hr etc.
First time I’m using the app for a long event and won’t be carrying 5 litres of liquid with me, makes sense to be able to portion up by bottle.
Back to the calculator for me. Glad I chose to portion stuff a few nights before.
@Dr_Alex_Harrison are you planning on calculating the glucose/fructose ratios? For example, I want to know how much gatorade powder and maltodextrin to mix together. Can’t seem to find the fructose:glucose ratio of Gatorade anywhere…
