Just joined the thread so sorry if repeat the question. Does the H3 have auto calibration? Sth like Kickr V5
Bonjour, jāai le mĆŖme problĆØme que vous. Avez vous des solutions ?
Jāai Ć©crit Ć Saris mais je nāai eu aucune rĆ©ponse.
Et vous?
Cordialement
Guillaume
No, the H3 must be manually calibrated with a spindown.
Ok thanks
Are there multiple BT connections on the H3? Could I do bot TR and Zwift at the same time, only using BT (obviously disconnecting the controllable trainer on Zwift)?
I have an H1 and can do it so it must be capable for H3. I regularly connect the H1 with Bluetooth to my phone and ant+ to my head unit. It seems that the ant+ from the hammer to my head unit (elemnt bolt) is a default.
Nope, single BLE only on the H3 and all other versions.
Dual use needs to include at least one ANT+ connection.
The duct-tape work around would be to possibly use an ANT+ to BLE bridging device like the 4iiii heart rate monitor or the one from CABLE. Iāve never tried it, but think others have used that tech and process to get another BLE stream for a 2nd device use, especially if it is āread onlyā and not for control.
Thanks for confirmingā¦I thought it was only a single BT connection.
I am using an ANT connection with my laptop, so Iām goodā¦was just hoping to simply things. The PC program for Zwift is just so slow to load, etc. I hate it.
Yeah, watching how fast my wife access Z on ATV is amazing compared to my older PC. I know I could upgrade to an SSD for an improvement, but will hold off for a full PC upgrade at some point.
Yupā¦if I am not running Zwift and TR concurrently, then my default is ATV for Zwift. Despite the horrors of the remote, it is so much easier than using a PC. The load is almost instantaneous by comparison!
does anyone have a rocker plate that works with the h3? I think i can get away with the lifeline version if i tweak the bladders to have different volumes in them? thoughts?
The trick I use for the Saris H series trainers is to partially fold the left leg back, and then strap it down. Thereās no need to have it fully extended when using a rocker.
As to your comment on spring volume, just use a proper counterweight at 10lbs [5kg] and use the same pressure technique as all other trainers and rockers.
Will adjust my left leg on the Saris for tomorrowās ride!!!
thank you for this!
do you not have a 5kg weight as i cant see it in your photo?
and where would you put it? next to the side of the trainer on the drive side?
That is a random photo I found in our Rocker Plate group on FB. I just grabbed it because it shows the leg position well. It is entirely possible to level a rocker without a counterweight, but the results are best when using one. Here are my specific instructions about how to setup a rocker with a counterweight:
Ignore the leg position here, but this is another example I grabbed from the group that shows basic counterweight placement:
Make sure to tie any weight down to the rocker so it does not move after you have finalized the location in the steps above.
This is great info. Thanks @mcneese.chad!
Hi all, way back in 2020 there were discussions on here about a grinding noise from S3s. Iāve had my S3 for almost 3 years, its been solid but I did replace the power cable! I had the grinding noise once before and it just fixed itself⦠but now its back! It only happens in the smaller rings (ie tougher gears) which makes no sense to me. I was wondering if anyone had a definite fix for this issue?
Iāve been having this lately too- in the hardest gears, thereās a clunking feeling, like I can feel the chain mating with each individual cassette tooth. I thought it was my drivetrain, got a new chain and cassette, and was about to get a new chainring before realizing it was only happening indoors, even with the same cassette on my wheel outside. Itās very odd.
Sounds similar. Iād describe is as feeling almost like thereās sand being ground down within the teeth/cogs/ axle or somewhere as i peddleā¦when i change gear so the chain is aligned with the front derailleur it stops. Iām going to try a few combinations:
- Small front ring, try each rear cog
- Large front ring, try each cog
- Do this in both erg and resistance mode
- Try on the flat or going uphill in erg mode
- Etc
