Saris H3 Discussion/Issues
  • How about unthreading and removing the axle adapter, tightening the cassette, and then returning the adapter to the trainer?
I’m pretty sure the adapter doesn’t fit through the lock nut from the outside. I can dismount the bike and try it, but I think I already looked into doing it that way. It’s crazy to me that this is even a “thing” that requires any thought whatsoever. First for me in like 15 years of using trainers!
I’m over screwing around with this new trainer setup. Constantly adjusting things the last week to get it dialed… hopefully once it is I’m able to get as much use out of it as I did with the Venge just on the trainer on the floor! :laughing:
Get a lock ring tool that is also meant to install / remove the lock rings for disc rotors. This one worked in my H3.
Hello everyone, I’ve just bought the H3, coming from a TACX Vortex Smart wheel-on trainer. I’m experiencing some strange behavior with power measurements: it goes up and down without being “steady” at target power (see figure), something I’ve never experienced with the TACX trainer. I’ve updated the H3 to the last firmware and done a calibration before the workout. I’m running a 11-speed MTB Shimano SLX cassette if it matters.
Someone has the same issue and knows how to solve? It’s pretty annoying… Thank you!
This is what is supposed to look like - your previous trainer was lying to you
you could adjust the smoothing, but true reality this screenshot is normal
I see… Thank you for the answer, power smoothing is set to 3 seconds, gonna try with 5.
Yeah, there’s nothing wrong with that power graph. Your prior trainer using erg mode power smoothing was just lying to you.
Received my H3 back from Saris- this is what they replaced. The list means nothing to me but it looks like they replace a lot of internals.
I have completed a couple of workouts and things appear to be smooth. But I have notice a significant lag when the power ramps up on an interval. Like greater than 5 seconds.
Mine also has the 5 or so second power lag on intervals changing
I bought an H3 with the last deal, so I can’t confirm that this works personally, but I saw that someone posted on Reddit that the code SCG-50-BLACKHAWK is good for 50% off on the H3 direct from Saris. I don’t know whether that influences your decision at all. I went through a similar decision making process (H3 vs Hub or Volt) and personally felt like the H3 was a better fit for my needs. I use a decent amount of ERG mode, and the H3 gets great marks there. I also got the MP1 discounted with the same previous code, and I was interested in a rocker platform, so that also impacted my decision. Given the potential firmware issues with the Hub, I personally feel like the H3, which has been around for a few years now to work through teething issues, is a better option if you can get it for sub-$500.
Ouch, not a great start for their “new” trainer :stuck_out_tongue:
I am hoping Saris can right their ship, but stuff like this is not a promising sign for them to get back into shape.
A similar issue happened to me 5 years ago… Increased thru-axle compatibility was a headline feature of the Kickr 2017, but Wahoo’s dual-sided adapter was too thick to fit my 2015 Domane and they were unaware until I reported it. Now if they would only make an XDR freehub for that model, I wouldn’t have to waste time trying to sell it.
Yeah, that kinda tracks with their situation TBH. Likely trying to force out the H4 quickly to try and generate revenue to gain the interest of potential suitors.
Just stunning though that they never bothe3d to check and see if a 12 spd cassette actually worked.
Has anyone seen their H3 produce red dust? Tried reaching out to Saris but after like 2 weeks they sent me a generic copy paste email that was like “Please tell us your shipping address, the serial number, describe the problem… etc” Which suggests they didn’t even look at my original email.
Now that is weird! Hope you get it sorted out. You take it apart yet?
Nope still riding it, haven’t received a second response from Saris since I sent them all the requested info and the picture.
hasn’t SARIS been sold recently due to them going bankrupt? I wouldn’t expect a response any time soon if that is the case. I have one of these as well and will go with one of the other ones when this one eventually fails…
Is it possible this is from the belt? Seems like a misaligned belt would be likely to produce dust with excessive wear. Maybe open it up and check how to belt is seated?
I haven’t opened up my H3 to check, but if I remember right the stock belt on my original Hammer was red.
Saris got back to me and said its the belt, I think they are gonna send me a replacement but it must be misaligned to all of the sudden start getting ate up like it seems to be, the squeaking is annoying to but comes and goes, thought it was my chain at first, kept waxing the bajezus out of it and I was like “ARGGGHHH why won’t you stop squeaking?” lol.
Hopefully the send some instructions on how to change and align the belt.
Your seat post is laughing in the background.
