Saris H3 Discussion/Issues
OK, I misunderstood your goals.
I don’t have a Garmin, but is it possible to preselect “Speed” sensor as the device, and then pick the Hammer ID for that on the head unit?
Which garmin do you have?
Forerunner 935
Quick update regarding speed data being translated to distance on 3rd party apps (e.g. strava): although the TR app does not calculate speeddata when you set your wheel circumference to 0, strava will still show „distance“ travelled. So left with disregarding it for good.
Thanks for the update.
Let me look as I used to have a 935 and currently use a 6X. I don’t have a H3 yet but one is on order.
For everyone that does have one do you all use your wheel quick release skewer that is on your wheel or did you buy a separate one to use? Customer service said the normal skewer works fine which is why it does not come with one.
I get a skewer just for the trainer:
  1. I like the added peace of mind from using a “trainer” skewer.
  2. I find it a pain to swap the skewer each time I bounce between the trainer and outside wheel.
Makes sense.
I just use a regular road skewer
Tredz have £100 off a £750 spend this weekend so the H3 is £749 - is this the best price in the UK for black Friday?
0% finance too which is handy…
Been busy and set aside today to unbox and setup my H3. Wow. What a *#$&ing joke. The box had a little bit of damage, but the trainer is absolutely destroyed. It looks like there’s a steel plate on the bottom that is bent way up. This thing was obviously dropped from a pretty good height. No foam around the trainer in the box, just a bid of cardboard. Thanks REI and Saris. I’m skeptical that this happened in shipping. Maybe. So joy, now I wait until Saturday to return since REI protests black Friday. :rage:
Holy crap. Definitely shipping damage. Having gone through 3 of them, there’s no foam in the boxes, just those cardboard cutouts.
Sorry for your troubles man
Pick up my H2 yesterday. What I can say it is big update from my wheel on Bkool Smart Pro.
Also noise level is overestimated for H2 based on DCR video.
Right now have problem to update my firmware via Saris Android up. Have a red light on H2 and nothing happens…
So sorry to hear it. Hope you will receive a replacement soon.
Was nervous about my because it was shipped from Germany to Ukraine.
What part of Ukraine are you from? I was born in Kiev and moved to USA in 1998.
I live in Berdyansk (Zaporozhye region) near Azov sea. How I like when East wind blows here :joy:
In my case when I try to update firmware I have following messages:
Updating device > Downloading Firmware > Device search screen with Saris_boot device.
At this time LED became red.
Will contact support cause I have same issue on another phone too.
So I got my H3 last night from Clevertraining and just set it up. What does a bad pulley sound like? Is it like this? Same cassette (105 11 speed 11-28t) as my wheel so I don’t think it is indexing.
Doesn’t sound like pulley slip to me.
Even if you use the same cassette, you van have problems.
  1. There are often small tolerance differences between the final cassette location between tour wheel and the trainer. I routinely have to dial half to a full turn.
  2. Possible wear differences from a new cassette and a more worn chain can lead to more noise. Do you know if your chain is worn?
What Chad said. You also appeared to start in the smallest cog out back which is noisier. If you want to check for belt slip throw it in the small ring, middle of cassette, and hammer the pedals as hard as you can. You’ll know if you hear it
Need to replace my chain for sure which I bought a new one. Will switch it and see. Thanks for the response and it does feel bomb proof.
