Rouvy syncing with TrainerRoad
Stuck in the great white north this winter and have been using Rouvy to cure the boredom. Miss loading up my TR app and trying all the new AI stuff. Even a simple export like the post above suggests would be awesome.
+1 for Rouvy syncing. While I started again with TR since they came up with the AI update I still feel that the UI is rather boring. Would be great to have the same integration as with Zwift. As a workaround I exported to Zwift (without an active account) and imported the .zwo file into Rouvy. That worked for the workout but it was not “accepted” by TR when I finished the workout and it got synced to TR again. It came up as an outdoor ride as far as I see.
+1
ROUVY has partnered with Life Time to add Leadville, UNBOUND, and several other courses. It would be cool to do my sweet spot intervals while pedaling up Columbine!
You should be able to match the Rouvy ride to the TR workout once its syncs to TR.
You could also run Rouvy and TR and use TR to control the trainer
So I leave the workout in the calendar, record the ride with Rouvy and then match it to the workout. How can I match it? Is there a button or function for this? Thanks!
Select the Rouvy ride that was synced and near the bottom there is an option to match it to a workout. And it should show the TR workout that is on the same day.
Thank you, I try that tomorrow:-)
Have you tried capturing the HR/Power/etc telemetry directly with a Garmin device and linking TR/Garmin? (i.e., Rouvy isn’t syncing to Garmin… Garmin is getting the data directly from your devices). I’ve done something similar in the past and had rouvy rides syncing, but its been about a year…
Tested it, worked absolutely flawless:-)
Terrific. Glad it worked. It’s a nice feature
Another +1 for Rouvy integration
Please add one more request to the list, integration with Rouvy would be awesome!
+1
+1
+1
Is there a Rouvy forum or community to make the converse feature request? I’d love to do my TR workouts on Ironman courses, but like Eddie said, it takes two to tango.
There is a Facebook page, https://www.facebook.com/groups/171879510187977
And one more +1 please!
Another vote for rouvy integration…
Thats what I do so the “ride” will still qualify for Rouvy Challenges.
