Ride showing as Pinned on calendar when I haven't pinned them
Hello all
on 4/26 and 5/3 I have my endurance rides showing up as pinned rides without me setting them that way.
I’ve tried switching rides around, pinning and depinning to get them back to normal with no luck.
Has anyone ran into this before.
TR staff if needed you have permission to share details in my calendar, thank you.
This is weird.
I feel like I’ve seen this happen once or twice before, but I had assumed in those cases that maybe those workouts were pinned on accident.
In your case, I’m not sure what’s going on here.
Do you remember when you noticed that these were first pinned?
This was today, I was checking what was the ride on the card for those to days.
When I cycled into the card that’s when it happened.
I then tried to switch workouts with an alternate then switch it back to see if it would fix itself, no luck.
This might be a tough one to try to reproduce on our end, since we don’t know what would have caused that to happen. If you think of anything, let me know.
Regardless, I’m reporting this to the team to see if anyone has any ideas.. :light_bulb:
Thanks Eddie, all that I can think of now to see if it’s just some type of visual bug and the workout changes as I do this week’s workouts.
Did you, by chance, use Workout Alternates or reject the yellow day notification when you got it?
It sounds like those actions will pin workouts..
I didn’t reject it the yellow day but did go into the page to check it.
This page, that is when the pinning started.
So you just closed out of that window rather than selecting “Endurance Ride” or “Easy Ride.” Is that right?
Yes. I knew that it would most likely change as I get to Sunday.
After I saw the pin is when I started selecting one ride then going back to the recommended ride to try and get rid of the pin.
Eddie, I started messing around with the ride time, just going back and forth on this page between two random times.
Somehow that did the trick and the pin went away for 4/26.
For the second Sunday 5/3 I did the same but that one eventually the pin showed up in the workout page and I was able to Unpin it.
Don’t know if any of this will help in the future.
Weird. I imagine that this is actually unrelated. Changing the time likely opens up the workout to the recommender again, since the work you’ll be able to do does depend somewhat on when in the day you’re going to do it (how long has it been since your last workout, etc.).
