Using a speed sensor and virtual power, my wattage is higher than my training bike with 4iiii cranks for the same effort, so should i use box section wheels on rollers?
Virtual power is not meant to give you an actual estimate of your power output. Virtual power merely gives you a reference point to measure your effort against.
thanks @bherbers, so as long as im consistant with equipment, i’ll continue on the rollers using my previous roller rides as a benchmark.
