Hi, TR app doesn’t see my Quarq elsa. Wahoo Elemnt does. New battery. Advice?
That power meter is ANT+ only for data broadcast, right?
Does the device you use for the TR app offer ANT+?
@mcneese.chad is correct! Quarq Elsa power meter’s are only ANT+ compatible.
Looks like you’re on an iPhone, but have managed to pair you Stages power meter instead of the Quarq Elsa.
To be able to pair via ANT+ using an iPhone you will need a Wahoo ANT+ key and an Apple 30-Pin to Lightning adapter. However, Apple stopped making these adapters so your best bet is to find them in eBay.
Another option would be to use a laptop and get a USB stick to connect via ANT+.
More info on ANT+ Connectivity here: ANT+ Connectivity
thanks so much!
