My INSCYD report
@abalakov - the 2 second lactate rest figure, is that standard or user specific?
Cheers,
Dave
But the combination of intensity and time wouldn’t be a rate, would it? It would be a capacity, and if the floor is VO2max, then it would be the maximal accumulated oxygen deficit (MAOD). Are you
saying that INSCYD has just taken that classic concept and renamed it VLaMax?
VLamax is an old and particularly dumb concept the way it’s applied by mader/heck/inscyd. Blood lactate dynamics do not determine anything about the capacity of the electron transport chain, and relating the two misses a lot of, frankly, very basic regulatory issues with metabolism.
I saw the tweetstorm by Coggan that led to that reply - wasn’t his claim that lactate production isn’t limited by enzyme activity?
I’m 100% certain they use the mader/heck model, and then Jeukendreup’s on top of that. Weber likes to hint they have made advancements but if you look at the outputs, they haven’t. I’ve exchanged words with him privately and get the same runaround. Coggan is an actual scientist with things to do, Weber is a salesman. But I read that exchange before Coggan’s twitter was deleted, and I can tell you for a certainty that neither of them are biochemists.
Coggan actually is correct that lactate production isn’t solely limited by enzyme capacity, but what he didn’t say is that at some points it can be. His point is that it’s reactive, and he’s right about that.
I’m wondering then how it is that Weber et al. get good and rational results from applying this model to at least some of their athletes. I guess there is always the chance that for those athletes, the flawed model matches up with reality (and maybe that’s why other people’s incsyd test results sometimes dont’ seem to make any sense).
I guess there’s also the possibility that a coach identifies a training intervention that produces results, even if their understanding of the how and why is incorrect. Eg., had a rowing coach who prescribed “peak power” sprints and maximum drag factor. Leaving aside that this is peak force and not necessarily peak power, his rationale was that if you can raise up your peak power, your 2k pace is a smaller percentage of it, ergo it’s easier. I think the intervention improved a lot of our 2k times but i don’t think that was the reason . . .
I thought Coggan said that he majored in biochemistry?
If Coggan did biochem, then he’s not up on the lit. The last couple studies he’s posted didn’t show what he thought they did, the same way his study with Coyle on ftp % of vo2max doesn’t show what it apparently does.
Which studies are those?
My lady’s rowing workouts are the same way, including “peak power” stuff that’s really not even peak force or power.
Weber will always mention that you can input actual lab data into the model, and that they’ve never been just about power data (even though that’s exactly how it was sold to me when he gave a talk in Boston a few years ago). But of course even with lab data you’re not going to get the right outputs. Stopped clocks, etc, a lot like other fudge factor tests. Anyway. If what they do actually works for someone, that’s fine, but I’m sure it’s not as correct as it could be, and when you base everything in your world around lactate, you’re gonna come up with some funny ideas. I’ll have a comprehensive podcast and probably TP article on the actual metabolic control points at some point in the next few months.
Excuse the generalisation & naivety of what I’m about to ask — would this mean that World Tour-level pro riders perhaps aren’t doing/shouldn’t do classic “5min@120%” VO2max training but perhaps mostly things like Seiler’s 8min@108%?
(Not introducing Seiler for criticism, but just as a point of compare & contrast.)
Always appreciate your contributions. :+1:
No, Seiler’s approach would be like a lot of approaches and only get between “meh” results and good results. One of the purposes of the last couple vo2max podcasts is to establish the idea that vo2max power is not tied to power, it’s tied to demand for oxygen.
My preference is for a training regimen that is guaranteed to produce adaptation and not make someone potentially waste a couple weeks or months only to find out that we have no result. The drawback to my approach is that recovery periods vary athlete to athlete. You can rest and test after a week or two and see no result (because residual fatigue is still there), but a month or two down the road you’ll see the improvements you were expecting. It’s why I’ve seen a lot of guys race a grand tour, then rest for a month and test some huge new vo2max value. Would be nice if it was there before the vuelta, right? But without the vuelta you wouldn’t have those adaptations.
Could you expand a little?
Thanks!
One study we looked at in depth here: Watts Doc #11: FTP vs VO2max - Empirical Cycling It supposedly shows that people with a higher FTP as % of vo2max will have better endurance, but it does not. It just shows that you can ride at a % of your vo2max longer if you’re at or below threshold.
Thanks @GilbertsGrapes - after skimming the papers linked in show notes, I (sort of) get it now though need to dig in a little more.
Have you actually read the study? It shows a strong, linear relationship between % of threshold and time to fatigue. Your interpretation would only be correct if there were no such correlation, but there was still a difference between groups on average.
Have you actually listened to the episode where we have an extremely detailed breakdown of the methods and conclusions? Nevermind, I know the answer.
Looking forward to listen to your podcast, @empiricalcycling
So, checking my RER from last Vo2 lab test (from last year - FTP is up a fair bit since then), gives an efficiency of 27% at FTP (going on the calculations detailed in the Watts Doc episode above) - FTP O2 (3.7L/min) falling at 74% of VO2 Max 02 (5.0 L/min).
Correlating that with the figures stated in the paper given in the show notes, gives approx 90% Type I fiber.
I’m a TT’er…thankfully.
Sorry, no, I don’t like listening to podcasts. I find speech to be an annoyingly-slow means of information transfer. I can understand, however, why you’d rather not type out your arguments all over again.
Regardless, I still think that you are wrong in how you are interpreting the study. You claim that the study only shows a dichotomous relationship. In fact, Figure 1 of the study shows a continuous relationship between time-to-fatigue and % of VO2max at LT. Critically, it also shows that this relationship exists in both the below-LT group and the high-LT group separately. The authors’ interpretation is therefore correct.
