Vo2max workouts - Time above 88% max Heart Rate
Putting this little table here so I can find it again in the future. Folks are welcome to copy, paste, use the numbers for whatever they are worth. Notes below on recovery times and RPE.
For VO2max workouts a metric we see utilized is time above 90% max heart rate. As a proxy. Since measuring VO2max requires special equipment it is difficult to determine if this type of work increases an individual’s VO2max. Regardless, there is interest in different workout structures, TiZ, time above 90% etc. I used time above 88% simply because 150 bpm is an easy number to work off of.
Notes
Inside my HR goes up higher than outside. That’s cooling or lack thereof. I also struggle on really hot race days (time trials). HR goes up fast and stays up.
Looking at the chart, it is pretty clear if one wants to simply accumulate time above 88-90% mHR, then longer time periods at 95-105% of MLSS (FTP) is a pretty good way to accumulate those minutes. A single 20 min effort in the 105% range is approximate to many of the common “VO2max” workouts.
I like 3 min higher power intervals and often choose 8 x 3 sets. 8 x 3 constant power holding 125-130% of MLSS gives about 10-11 min >90% Adding hot starts bumps that up to 16 min. Problem with 8x3 hot starts is it takes me a 2-3 days to recover well. Compared to 1-2 days for a hard 2 x 20 or 5 x 10
4 x 8 starts to accumulate a good amount of minutes in target range. 22:00 for the example shown. I find 4 x 8 inside at 105-110% extremely difficult. Outside not too bad. Recovery time is 2-3 days
Finally, if we only want minutes above 90%, go do FTP work and you’ll get there. Or at least I get there.
The 2 x 20 shown was a good day. I breezed through both at 106 and 102% 32 min above 90%
5 x 10 Inside (two different TR Antelope records) is pretty good at getting my HR up. Almost 40 min total time > 90%
Recovery time for a 2x20 or 5x10 is 1-2 days
W:R 1:1 for intervals up to about 5 min. 2:1 or other shorter recovery would increase time above 90% of course
Take Home - At least for me, if accumulating time above 90% mHR is the goal, looks best to just go ride at 95-105% of FTP and let the minutes enter then bank. Of course for racing or trail riding there are other power demands and trainings to consider and perhaps the higher power intervals provide extra bang for the buck there.
$0.02 There are other blogs and data sets out there better the this one so poke around if really interested in precise information.
