Searched but no results. What setting should my wheel circumference be in TrainerRoad on the Kickr Bike Shift?
Thx.
Thx.
Hey @andylaiphoto!
Great question. In TrainerRoad, the default Wheel Circumference is set to 2096, which is based on a 700C wheel with a 23mm tire.
Note: if you have a different wheel size, that’s OK. The difference in wheel circumference won’t significantly affect your speed or distance readings. While you can certainly update it to match your specific tire size, e.g., 2152 for a 32mm tire, we generally recommend leaving it at 2096. The key is that it stays in this ballpark for accurate readings, and you’re all set.
Thanks!
Welcome!!
