🎉🎉🎉 Introducing Plan Builder! 🎉🎉🎉
Select a discipline. Is there a generic option for Running? My workaround has been to add a triathlon race that has a matching distance for the run.
Starting to train for my first attempt at an open marathon the end of April, playing with Plan Builder to see how it would schedule things for an A-priority running race followed by a long training block leading to two A-priority full distance tri races that are 10-weeks apart. Busy year!
Now to figure out how to work in riding and swimming during 18-weeks of marathon prep. Will be using the Hanson’s Running Method with hopes of A) being consistent, and B) building running mileage safely. Hoping this will set the stage for better runs at the tri’s as my run is significantly below average compared to swim and bike.
@Nate_Pearson @Geoff
Question of A races after reading the FAQ and responses above; I’ve got two high priority events within 3 weeks. State road and state crit champs. Neither is a “B” event, its more like 1A and 2A.
Based on the algorithm you are using is it better to schedule the A event in Plan Builder as the first event or second? Obviously all of the lead up training is geared around the A event based on the playing around I have done. Is it better to schedule it first and try and bask in the “afterglow” of holding A race fitness for 3 weeks until the next event, or try and hit the first of the two events part way through specialty (which is how plan builder ends up planning it).
Thanks
Depends on how you respond. Some athletes can hold a peak for a month. If you think this is you, I’d go A for the first event.
If not, make it a B event and maybe take an extra day.
Rest week at the same time as a stage race? Followed by a fairly heavy week?
Loving the Plan Builder progress. So much potential with this tool. Went back in to run builder for next year again now that it’s been pushed to general release and came across a small bug during the build process.
Was setting the start date as Jan 21, 2020 and noticed the whole month would not display for the calendar and there was no way to scroll down and show the second half of the month. I can still start on the right date if i type in the date instead of selecting the calendar pop-up.
This feature is fantastic, however, as a triathlete I (and I assume others) often take part in single discipline events, e.g. a 10k, half marathon, marathon etc.
The first time I ran plan builder I input these as triathlons and then adjusted the swim & bike portions to zero, I am now doing again excluding them entirely and will factor them in myself, but would be great to be able to put these in properly as single events. Apologies if this has already been raised!
getting some strange activity in the race weeks on plan builder, the race day keeps being moved forward with workouts now doubbaling up
i am having the same recommendation from the plan builder:
ssb1 > sustained pw build > ssb2 > sustained pw build > ssb2 > specialty climbing road race
i choose high volume and experience level “expert”. i also tried it with exp. level “advanced” and got a result in which the traditional cycle base > build > specialty was recommend.
whats the difference between exp. level “advanced” and “expert” and what are the benefits of each approach regarding the different phases before the specialty phase. Thank you!
same situation
I had to set the first race to A and second to B type because other way I had not the specialty plan before the first race (de facto mistakenly setting the peak at the second race)
Hello,
I just played arround with the new plan builder. Great tool, I realy like it.
Unfortunately, I think I found some small issues.
If you include a plan without any race goals and then add a race later I don’t get the option for recalculating plan.
If I included at least one A-Race when generating the plan I get this option and can recalculate the plan. But, if I then delete the A Race later, the option for recalculation doesn’t show.
Maybe one small point of convenience. As the recalculation of a plan can take up a little time It might be a good idea to somehow show that an calculation is in process. Right now the user don’t know if any work is in process and therefore might do/start things that leads to unwanted/unexpected states.
Cheers and keep up the good work.
@AgingCannon this makes alont of sense. Will redo the plan like that then. :+1:
Little new feature request or question (did not see it mentioned before):
Would be nice to have a simple calendar note on your B/C races showing which workout got replaced by the race. So if you need to skip the race you have the alternative workout.
Or is the use case to delete the race instead and have plan being recalculated? (But you might want to keep the race in the calendar anyway so a note would be helpful)
Not sure I am asking this question in the right manner, let me know.
When answering the questions, and based on past training history, the recommendation is low volume, which if selected carries through the plan. Is there a way to begin with low volume, and use that for first base period, and maybe even build, but then switch to mid volume for the next base period prior to the final specialty phase? Apologies if asked already.
On the Setting page, turn on the “Customize training days for each block” option. This opens access to all the phases, and allow lots of custom options for each, to include Volume.
You can also adjust once it’s on the calendar by opening the annotation for each phase, and adjusting there.
So it can be done during step or after.
Got workouts doubled too
@SSaldanha my hunch is that the events where you have duplicates are places where workouts were manually moved once your plan was applied. If you drag-and-drop a workout to another day once it is on your calendar, it will lose its association with the plan, and therefore not be deleted when you complete your custom plan. My recommendation would actually be to delete your plan, delete any workouts that remain, and build your plan again. Fortunately your events will be detected when you run through the flow again!
If you do this and still run into duplicates I’d definitely like to take a deeper look to make sure there isn’t some sort of bug going on.
@Focus were working on an update for this. While I’m not sure it will be in before the holidays, expect it shortly after if not.
This statement should be in the FAQ.
Hopefully this can also be changed in the future so things WILL stay connected to the plan. All depends on the logic behind the scenes.
How do we make edits to our personalized plan after the fact? I want to add in openers prior to B races.
Thank you.
Matt
