Did you record your ride with a mobile device and the TR app?
If so, there will not be any GPS data, even Iād you switch it to Outside ride.
You should be recording your ride with a regular GPS based head unit. Then upload it to a site like Garmin Connect or Stava. Finally, you want that site synced to TR and it will be pulled into TR automatically.
Thatās what I did. I started the workout on my Bolt and the TR App simultaneously. After 90min the workout automatically uploaded itself to Strava. I rode back home, which took another 5min and manually stopped the workout on my Wahoo headunit, which uploaded the workout to strava as well. Now I have two workouts on strava - one from TR and one from my Wahoo Bolt. I have no idea how I can merge those two on TR or on strava. I even tried to manually upload the gpx file to TR, but it wonāt show up as a workout. On strava for the TR workout it says indoor ride. So maybe I forgot to switch to outdoor training and thatās why the site refuses to add the gps data from the headunit? Just a wild guess
As chad advised - do not upload rides from multiple devices. Most platforms will reject / ignore the second upload.
To resolve the situation you can delete the rides from Strava and TR and then re-upload to Strava from the Wahoo Elemnt app. This should then trigger a proper sync to TR.
Note: you will of course lose the TR recording from your phone.
thank you @mcneese.chad and @Agglo for your responses. I wonāt delete my TR workout since my powermeter was paired to my phone and thus power was only recorded within TR. I donāt know if I can connect my powermeter to both phone and headunit. If not, I donāt know how I would do workouts outside. Write down intervalls and tape it to the stem? Seems like Iāll be waiting for wahoo to support TR workouts. I wrote their support today. Maybe with enough demand from the community, we wonāt have to wait much longerā¦
This is great news, I have an outdoor velodrome 5km away so doing TR workouts outdoors is feasible. Will all the Garmin features be available on my Garmin 820? Or do I need the newer 830?
You should be able to connect your PM to the Bolt via Ant+ without consequence for your second device. Just avoid Bluetooth (which is a 1:1 connection). Just disable automatic sync for one device and you should be good.
So the PM sends a signal through both channels (ANT+ & BLE)? I donāt think my phone supports ANT+⦠Have to try it out next time if Iām able to connect both headunit and phone. Will report back.
Most modern PMs transmit on both channels⦠depends on your model of course. Just connect it via BT to your phone and see if the Bolt can still connect to it. If it can - thatās Ant+.
Make sure to first remove the PM from the Bolt if it is already registered as a BT connection. Otherwise the Bolt may block the BT connection whenever you turn it on first.
My general rule is: I use Ant+ for all sensors (power, HR, cadence) with my head unit and leave BT free for my phone / tablet device (which in my case donāt support Ant+).
Hi, I have a question, how can I do these workouts outside but without a pwoermeter, I only have a Heart Rate Monitor to know what effort Iām doing, is there any table that converts for example 90% of FTP power is equal to a % of my Max Heart Rate?
I need to know these because Iām really bad doing workouts without a parameter, when I have power in my smart trainer its perfect, but outside I donāt know how to do, and doing them by RPE don`t works for me.
Thanks! One more question, to calculate my max heart rate and my heart rate threshold what should I do? Is there any test like a ftp test or something like that but to calculate the max hr and lactate threshold hr?
Now that our snow is finally gone I was about to ask if you could just release the garmin outdoor workouts⦠But now its forest fire season and Iām stuck in the basement again because of air quality. lol
