I must have done a very poor job of communicating my thoughts because neither of the points you attributed to me were actually anything close to what I was trying to express.
But thanks for the reply anyway, I guess. Itās cool how active you are on the forum. Good luck with the outside ride feature and training plan API implementation.
The combination of all of this is looking really good. Thanks, TR team. Outside workouts directly imported into my Elemnt sounds like heaven. The idea of flexibility in timing through a lap button would be particularly usefulā¦
With the new Garmin API announced, will we have the option of pushing the indoor workouts to Edge head units as well or will this be limited to outdoor workouts?
Iāve never really stuck to a plan shock horror but chosen individual workouts based on time/fatigue/weather. Will we be able to push individual workouts to our head units in a piecemeal fashion or do we have to have a plan in the calendar?
Will we be able to push custom workouts to our head units as well, or only workouts created by coach chad?
Great news thanks.
Canāt wait for head unit integration.
But until then, could you maybe also work on audio cues from the phone app?
Narrated by coach Chad of course
Iām lucky to have a former airbase runway a 30 minutes warmup ride away, so up until now Iāve been able to do some TR-classic workouts there undisturbed, but this new feature is great news.
Thanks for the continued work you put into TR.
Much of TRās value to me are the workouts and plans themselves. There are cheaper apps that show you bar charts, but nothing like a plan that Iām actually going execute and that works for me (Iāve done the 70.3 base and build) after 3 seasons of not-always-satisfactory progress with other āvendorsā. So the fact that youāve gone beyond laying outside rides over planned workouts and that Chad has taken the time to āconvertā indoor to outdoor, changing the structure of the workout, is absolutely yuuuuuuuuuuge!
It would be really interesting to hear on the podcast some of the reasoning behind the way the outdoor and indoor rides are matched. Some of the switches make a lot of sense in terms of making them more simple to complete outside, but others seem less intuitive from a physiology standpoint.
For example, I have Dicks -1 (5x8min 105% 5min recovery) being replaced by Mount Carru (3 sets of the following 3x3 minutes between 401-418 watts with 3 minutes easy between intervals). So the workout is going from sustained efforts just above threshold, to VO2 intervals at 120-125%.
Iām sure a lot of thought has gone into how the workouts are matched, but some more insight would be great. Even if only to get an idea of which styles of workouts may be better kept indoors.
If you read DCRās report from the Garmin meeting, the training plan API supports loads of Garmin devices. Now as to whether the TR implementation will allow it, thatās another question; but Garmin devices have supported structured plans for a long time as weāll.
Quick correction to this post I made earlier in light of @JHowās post (#273 in the thread, if youāre interested).
Clearly what I SHOULD have said was ābecause there is no way with my current skill set that I personally could execute a workout like Junction outdoors with any level of accuracy or quality although clearly others probably couldā.
We tested the idea of having a time multiplier for endurance workouts to account for this, but since that doesnāt allow us to account for everyoneās unique terrain situation this ended up not being the best solution. We came back to the idea of having the prescribed time be similar for endurance outside workouts with the disclaimer that you may need to ride longer than is planned to hit the prescribed TSS.
The prescribed workout instructions are meant to net the correct TSS, so if you are able to execute on those to the best of your ability then the amount of additional time needed after the fact should be reasonable. The alternative to this would have meant a prescribed workout that didnāt match what the prescribed duration was, and we felt this would have led to more confusion overall.
