Is there any correlation between the .IF and KJS you burn over an hour period. I’ve been looking at my kjs burnt and .IF and found its pretty close .60If will be around 600kjs. And TSS will be around 60 as well.
Maybes I’ve missed this in a Podcast I cant recall a similar discussion.
I’m not so sure that is correct. In fact I’m pretty sure it’s not.
1hr at precisely your set FTP = an IF of 1.
Does an IF of 1 always mean a TSS of 100? I’d suggest not because TSS (by design) can be accumulated in various ways… long/slow or short/fast (both of which will result in wildly different IF’s).
As to Kj… this is simply a (precise) measurement of exactly how much energy you’ve put into the bike. It is unfiltered, raw data as measured by your power meter. The other metrics being discussed are all “processed” based on whatever has been set as ones “FTP”.
Now a discussion on what FTP is, and what it is not, has been done to death. Hint: 99% of people are wrong on this, too.
If you ride long enough, you’ll eventually hit 100TSS.
You’ve gotta ride from the outset at “FTP” to get close to to an IF of 1… and the longer you’re below “FTP” at the beginning of your ride, the higher above “FTP” you’ve gotta go (and for longer) to get back up to an IF of 1.
