Help fix in-ride text typos; post them here 👇
Raymond +2
At 6 minutes, it says “3 minutes at 94% FTP” but it’s actually only 2.
Taylor -2 at about 52.35 “just a handul of repeats”
Lulushan: In the second paragraph of the goals description the workout refers to antelope. :smile:
Throughout “The Wing” the references to the workout (possibly all of them) are to “Echo,” a similar 90 minute tempo workout.
Mills +5:
At 41:20 “you level of fitness”, should be your
At 1:02:30 it says “30 seconds until the last interval” but thank god it’s 2:30 minutes
I just did this today and noticed the FTP references. Almost seems like the instructions are from a higher intensity version of the same workout? Is Whiteleaf perhaps a reduced-intensity 90 minute version of a harder/shorter 60 minute workout and the instructions just didn’t get adjusted accordingly?
“Kingsbury is 5x5-minute Threshold repeats between 95-99% FTP with 4-minute recoveries between each.”
yet when I finished, it congratulated me on completed SS work
Leavitt -5 at about 33:40 - it says “Fow now…” and should read “For now…”
Not a in-ride text typo, but a workout structure typo/mistake:
both The Thumb -2 and The Thumb -1 workouts have their second half 1% too high, so 116% instead of 115% and recoveries at 41% instead of 40%.
EDIT1:
Bashful +1:
50.50 foward instead of forward
55.10: well instead of we’ll (talk again …)
Might have missed some other ones, hard to keep up with the text during V02
EDIT2:
Bluebell +1:
Right at the start, near 1-minute mark, the text says “and we repeat that 5 times over” or something like that, but if I understand correctly, it should be 6*, since there are 6 intervals in each set.
I have always thought the typos were all there on purpose, to see if you were too cross-eyed to notice, or just to distract you from the burn in your legs!!
(copying from my other post in another thread b/c I couldn’t find this one again…)
I did “Beacon” and I noticed a typo in the on-screen text. Around 40 minutes into the workout, there’s onscreen text about moving your feet like you’re kicking a soccer ball. The screen says “your”, but it should be “you’re”.
Red Kaweah
20 seconds in it says sets consist of four 4-minute intervals when there are only 3 4 minute intervals per set. (I believe this is also the case for Red Kaweah -1)
48 mins - It says “Great job! Only one set left” I suspect this is a carry over from Red Kaweah -1 because there are definitely still two sets left.
Izaak Walton -1: Description typo (1) and Goals typo (1)
“over-uder” instead of “over-under”
“you?ll” instead of “you’ll”
“Escondido is 2.5 hours of Tempo intervals spent between 70-76% FTP with intermittent, 4-minute recoveries at 55% FTP.”
Escondido is 2.5 hours of riding at 76% for 7 minutes with intermittent, 4-minute recoveries at 60% FTP.
EDIT: Tenaya:
At 1:01:10 should be “your” not “you’re” heart rate
At 1:03:00 text says 2 mins but it should be 1 minute
At 1:55:50 it’s “the” but should be “they”
EDIT:
In Baxter -1 at 10:15 it should be “75 minutes”
EDIT:
I completed Vogelsang today and I have to say I’m pretty disappointed with the (lack of) workout text during the workout. I completed Tenaya on Monday and the text was 10/10, a whole lot of instructions on the drills that are incorporated in the workout, start and end cues etc. In Vogelsang, the same drills are prescribed in the workout goals, but the text is just like “incorporate some 5-minute endurance spinning intervals during this stretch to break the monotony”. Well, what if I don’t know what those are?
Is it possible to check longer workouts like this and maybe copy-paste these instructions into all of them?
EDIT:
Leavitt -4 and -5:
At 20: 55 “peformance” instead of “performance”
At 33:35 “fow now” instead of “for now”.
EDIT:
Markleeville consists of 2x3-minute and 3x3:30-minute repeats at 110% FTP, separated by 5-minute recovery valleys and followed by 30 minutes at 65% FTP.
there are 4x3:30 intervals
EDIT:
Izaak Walton:
At 1:24:00 the text says “for some a bit” … which is wrong
Cromerford:
“The time-crunched version of Carson consists…”
The text from Carson -3 doesn’t relate to that specific workout at times and references the sustained intervals of Carson.
Workout description suggests this workout has 11 intervals (8 @2min and 3@2.5min) whereas it actually only has 6 @2min.
On Emerald - 3
Main Set:
2 sets of the following:
  • 3x 2 minutes VO2 Max at 330 watts with 3 minnutes recovery.
  • 8 minutes recovery between sets.
workout description reads
Description
Cotorra totals over 85 minutes of Tempo intervals spent between 65-94% FTP with intermittent, 2.5-minute recoveries at 55% FTP.
The workout has four intervals of 18, 19, 18 and 19 minutes respectively, 74 minutes worth @ 93 - 94 FTP
The Chimneys +5 - Around 40 mins in, 90 seconds before the third interval the text gives advice saying “30 seconds to go” and gets you to prep for the interval, guessing it needs moving a minute later.
Red Lake +2
The ride instructions refer to 20 mins at super threshold, but clearly there are 5 x 5 minute intervals. As you approach the 4th interval the instructions encourage you to make it through the ‘last interval’ when clearly there is one more interval to go.
