My pedals have lateral play. I took them apart and the bearings are chewed up. Can anyone shed light on what size bearings I need please?
Define ‘chewed up’? Bearings are non-replaceable, BTW. You can purchase replacement pedal bodies as a service item.
I’d try the Garmin Rally forum.
Ah fair enough.
The bearings were sat in the end battery cap when I removed it and the housing and turned into like swarfega.
Cheers! I tried Garmin helpdesk and they weren’t that helpful. I’ll try the forum.
I have change bearings in garmin rally pedals. Did you find what you looking for?
Sadly I ended up buying a new pedal body. More expensive than I’d have anticipated but at least they work now ![]()
Ok I understand. Be sure to take the new ones apart at regular intervals and try replacing the old grease with new. Also clean the rubber seals. Here is a YT video on how to change bearings. https://youtu.be/VQk2Y46oRKo?si=rAKrGHwnzkpsjP5H
