Any of the plans are meant for more than a month for optimal gains. What you are seeing is that the specialty phase for Climbing predicts a higher value. You really need to be doing a 3 or 4 month plan and backdating the start if you’ve already done base, so that you can get a build then a specialty phase.
Not at all, and I’m glad to have helped.
I suspect TR will be looking toward that way of working in their development ![]()
Yes, we are in Beta testing. I just try to help in a way to bring up issues I think could be interesting as it could be bugs or not ideally set parameters.
Naming and labelling things different than a lot of users understand them is what rises misunderstandings and communication more difficult than it could be.
Now I see, there is implicit parameter, there are always phases. If a plan is only 1 month long system takes speciality phase which are set in advance. Why if something else would make intended result better in 1 month?
Ok, let us close this one. Some other time again!
