Effects of Inaccurate Power Measurement
I’ve been using a Kinetic dumb trainer with the little inRide pod since forever because it has always worked fine for my needs. I recently picked up some Favero Pro MX’s and did a quick comparison between the two. I did the usual warm-up before performing the spindown calibration of the inRide and noticed that the reported power was always approximately 10-15 watts less than what the Favero’s are reporting. Can someone explain in layman’s terms what the effects this would have on my training?
Because the Favero’s will be used on my outside bike and I really don’t want to bother with switching them back and forth, I’m curious if there are any workarounds within TR to compensate for the inaccurate measurement?
Thanks in advance.
Not within TR… but you can nerf the faveros in the app so they read low like your trainer…
Where do you do the majority or your TR workouts?
To be honest - I’m struggling to endorse any solution that involves continuing to use that dumb trainer for power :rofl:
I agree with @kevistraining :backhand_index_pointing_up:
The “best” option would be to calibrate your pedals to read the same as your Kinetic. You’ll be losing a few watts, but the main goal here is to have consistent training, which a calibration will help achieve.
It’s not super uncommon to see a discrepancy between indoor trainers and power pedals. If you aren’t able to use one power meter for everything, adjusting them to read similarly is the best option.
They are correct about the way to compensate.
In terms of effects on training, it shouldn’t matter too much as long as it is consistent. The numbers don’t really matter. Aka if your ftp is 200 vs 300 it doesn’t really matter outside of not being able to brag as much on this forum. Because all of the training will be based on that number. Now, if the trainer is inconsistent and is 10w less one day and 30w less the next and 10w more the next, that would be bad.
One word of warning before putting in any solution that isn’t just “use the faveros” - you absolutely need to check how that power difference varies as the trainer warms up.
My n=1 example of this was comparing my old Tacx wheel on trainer to my Faveros, the difference could vary anywhere from 50-20 W depending how warm the trainer was. If the difference is constant over your desired workout duraitons you can probably do what others have suggested and “turn down” the pedals in the favero app. If it varies, I would be very careful doing that!
Thanks everyone for the replies. There’s a chance I’ll be picking up a Wahoo Kicker this fall so the problem may become moot.
Agreed. I did this during a 30 minute ride so I could use the live view from the Favero app and monitor the difference. After five minutes of warming up, I did the spindown calibration from within the TR app on my iPad and noticed that the difference settled down to a consistent 10 watts so I think i can live with that until I get a new setup.
