Deals / Sales / Discounts for Fitness Stuff (2024)
BikeTiresDirect have auto codes for 25% off maxis and it looks like about 25% off most Conti’s too
PROMO CODE25MAXXISAPPLIED25% Off Maxxis Products
PROMO CODECONTI25APPLIEDSave on Select Continental Tires
Bite the tab with your teeth and twist/pull the packet. Very easy.
Maurten are very easy but you have to do it from the correct side. If I feel resistance I just turn the packet around 180 degrees
Nice one! Thanks!
The reason Maurten is not cut on both sides is so the tab stays attached, as long as you don’t rip it too hard. It’s a litter thing.
Good deal on rapha pro bib shorts
Efficient Velo has a 20% from now through end of the year
their tire inflators are second to none imho but not cheap
“Outfit & Save”
Rapha has 40% on a combo tights / jacket/long sleeve. Not a bad deal if you like the pieces on any of the combos they have
https://lynskeyperformance.com/
Lynskey has a bunch of discounted frames/bikes and then additional 35% off.
Specialized Roval Traverse wheels 60% off at bike24.
More from bike24: RockShox Sid SL Ultimate Brain 600€, USWE Outlander Pro 70€.
Zwift Ride 20% off:
35% off Tannus Tubeless Armour inserts for Black Friday (UK site):
Discount code for MyVeloFit
What better gift to give a friend than a better cycling experience? As a valued Pro user, you get an exclusive holiday deal: 50% off Pro Plan gift certificatesfor friends, family, and fellow cyclists.
:gift: Help the cyclists in your life ride stronger and more comfortably with MyVeloFit.
:hourglass_flowing_sand: Act now—this special offer is only available from Monday, Nov 25 to Monday, Dec 2 (Cyber Monday).
Use Code: PROGIFT50 at checkout.
Does anyone know if any of their gravel bikes would be good as a CX specific bike? Looks like Lynskey used to make a CX specific bike in the past and I’m not sure if their gravel bikes are that exact thing rebranded, or if it was changed to make it more of a “gravel” bike?
Would love a Ti build but also want to try to get a CX specific bike rather than another gravel bike!
Without having looked at the specific geometries in question, you can often quickly determine if it is a “true” CX bike vs. more gravel focused by comparing key dimensions such as BB drop (CX tends to be higher BB with drop <70mm), shorter reach and a shorter wheel base. Tire clearance could also come into play, but honestly, most CX bikes in the last decade or so have had clearance for at least 40mm.
Depends on your CX goals. I just gave up on my new “gravel” Crux and got the Cervelo R5-CX and it is muuuuch better. The Crux was fine but if you want to achieve then go CX specific.
Well id like to have something with a higher ceiling than my Lauf Seigla but ill be the first to admit that my bike isn’t the limiting factor in my current performance! That being said, in the spirit of this thread are there any good Black Friday deals on dedicated CX bikes?!
canecreek has their BF going now 40% entire website
Wow, just like last year
DT Swiss GRC 1400 Spline 42 gravel wheelset 1200€ at bike24. That is the previous model, not the most recent GRC 1400 Dicut model.
Garmin dropping the 540 to $250 for non solar and $300 for solar at most retailers. 840 marked down as well.
