Hey all, I’m making my first jump into cross this year and would like some help with equipment. I have my bike but would like it to fit similar to my road set up.
For a new bar and stem can I just use normal road parts? Or should I be cautious with certain brands? What are you using?
Buy known brands from appropriate dealers and retailers and you will be fine.
I avoid the lesser known brands, Ebay specials and Chinese knockoffs as a rule. Good deals can be found, but authenticity from some avenues is justifiably questionable. If it looks like too good of a deal, it probably is.
Just use normal road parts for bar and stem. Aluminium is fine. Cheap is fine.
It depends on what level you expect to be racing, but I don’t think many people are concerned about their bars.
Saddle, don’t use anything to fragile - you’ll jump on and put your whole weight on it. I’ve seen carbon rails snap.
Cross-specific things… tyres!! Some consideration to wheels.
Frame. How much mud clearance does it have. How easy is it too clean - avoid lots of tiny corners and features. Have a top tube thats not digging into your shoulder.
Brakes. Hydraulic discs if you can.
All bearings should be sealed and robust.
Bar tape - this should stay grippy even if muddy and wet.
Think about how easy everything is to clean, and how much abuse it can take. Also how much will it cost to replace, because you will fall of and might damage something.
