gel flask if you need lots of water. You can make your own or use commercial gel contents. I have Salomon 150ml and you do not even need to open them, just bite on the tip and squeeze. If water is not a problem I use a 500ml bidon which is even easier to use. In races I fill the bidon with the exact amount I plan to use which makes it easy to follow as well.
