Combining Long Aerobic + Intensity
Does anyone here do this or do you strictly keep endurance rides, endurance rides? If you mix the two, are you ever doing anaerobic work or do you keep it aerobic (VO2 and below) ?
I’m looking to make my training week(s) a bit more efficient and combine one of my HIT days with a couple hours of endurance riding (e.g. 5-min full gas every 30-min), but I’m not 100% it’s the most effective way to go about things.
I asked Trevor Connor of FastLabs about combining a long endurance ride with some anaerobic work and he said that he’s not a fan of it because the two can cancel each other, but admitted that the research he’s basing his POV on is very dated. He prefers to isolate high-intensity sessions and keep them separate from endurance sessions, however also said that if you’re stuck and must do them in the same session that it’s better than not doing them.
This makes sense if we’re talking mixing anaerobic work with aerobic work because the two are vastly different. However, maybe it’s totally fine so long as the HIT work remains aerobic.
I typically do my TR workout and then right into an endurance ride. I’ve wondered a few times whether there is a risk of blunting the effect of either.
My theory is that the endurance gains should be reasonable based on entering the endurance portion carrying fatigue already.
I’ve seen quite a few people mention they do SS or Threshold efforts during their long rides which I guess is similar, though not kitchen sink, or the exact same as my method with the interval focus separate to the endurance.
I’m interested to hear more thoughts.
I am not sure about anaerobic work but hard aerobic during endurance is great thing to improve fatigue resistance and get even more aerobic benefit (so sst and threshold during longer ride, spaced evenly during the ride).
I do not think that anaerobic has many sense in terms you want to push as much watts as you can - and it is hard when fatigued. Maybe from race specificity and mental side it has sense but I am not sure from training perspective. As far as I know everything anaerobic is best trained when rested.
Think that is actually what most pros do. For example someone just posted a workout from Alex Dowsett in the pro training thread which is exactly that, endurance with some efforts.
My specific example I asked Trever was if I front loaded a long ride with say 3-5x1 min full gas (anaerobic) efforts designed to target capacity. 1-min on, 5-min rest, repeat. Then finish the ride with say 2 hours of riding at low intensity. Would the following aerobic work blunt the potential adaptations from the anaerobic work?
Can’t see why it would. Agree with jarsson that if you want to do max anaerobic work, you want to be fresh, but I can’t see how it would harm the aerobic work after.
I think there’s only positive benefits to the method unless you are really, really trying to optimise your training for maximal one minute power (like Kilo racing/training or something) in which case you’d probably have more rest and perhaps not the Endurance.
For specificity for your racing which will still require a high level of endurance I think that’s a fine plan.
Tim Cusick has one of those in his plans - in third hour of endurance ride do 5x1 min attacks. Race specificity workout. I do not know how the things would cancel themselves. I am also sure you would push less watts when fresh so it would be not optimal workout to train 1min power rather accustom your body to those efforts when tired.
Totally understand the race-specificity thing. I guess it’s clear that if your goal is to maximize building anaerobic capacity you should probably make the workout focus only on that and do your endurance either later in the day or the day following.
I’m just looking for ways to be a little bit more nimble during CX season, when I’m already killing 3 days per week between openers, racing, and recovering.
So basically the answer is from ISM (Fast Talk episode about Race season) - treat race as a hard, HIIT workout (especially with CX) and do another hard workout during the week. Rest is endurance.
Cancelling out seems like a funny idea. So basically you don’t get any stronger from racing?
I do all of my intensity in my two long rides (2 days per week: Tuesday and Saturday). I ride for 3-4 hrs on these rides. I will work in anaerobic (all out sprints) or high intensity aerobic (vo2 or high end tempo/ SS). I don’t mix the two tho. However, I usually throw in an all out sprint at the end of the ride.
If I was to do anaerobic, I’d prefer to front load and do it 45-90mins in. When I do the vo2 and SS I do it spaced throughout the whole ride.
I did specifically train for a 1min max this winter and for that I did my intensity days separate in a 1 hr session. Same for a 3min max.
But I think building that fitness to be ready for typical racing, it is best to put these efforts into a long ride.
I only train 7-10hpw for reference.
I was coached and raced CX pretty successfully. If you’re racing every weekend or every other, you ought to treat the race as a workout. We always just rode endurance or recovered during the week and did a few efforts on a Wednesday. Something like this:
M easy <50% ftp or off
T z2 1.5-2hr
W 1.25-2 z2 with some efforts
R z2 1.25-1.5hr
F easy with an ftp to 120%effort or two
S race
S race /off
We would do a proper 2-4hr long ride if I was to take a week or two off racing. A race is way more stress on the body than your typical high intensity workout so we were pretty light on structured workouts in season.
I hope I didn’t come across as suggesting it would, I was curious IF it would, seeing as the two are vastly different systems. However, like you mentioned, a race (unless it’s some crazy long ultra event) will likely always have both. And from experience, fitness can be a great benefactor from racing.
I’m entering my 4th CX season, and am still new, as I’ve only done 18 races. Always wondered what kind of fitness benefit came from the races. I don’t have power on my CX bike so I have no idea how much time I’m spending in zones, all I know is that racing A) it hurts worse than any workout I do B) my HR is always at or above 95% max.
I reckon there has to be a good fitness benefit from racing, but I also would guess that CX is really bad for FTP. So I’m definitely looking to work in some FTP maintenance work throughout the season, but I’d also like to build FRC (currently @ ~24KJ…so not too bad)…which are at odds.
I’ve never focused on building higher anaerobic capacity, have always used racing to do that, but my understanding is that most people don’t need more than a week or two of this to get things moving.
Ok, cool. What if I did a ride that looked like this:
20-min WU
1-min full gas (w/7-min recovery @ Z1) Repeated 4-5x
90-120 min Z2
Maybe I misunderstood the abstract and the beginning of the study, but it looked like it was comparing minimizing negative effects of combining (high volume endurance + resistance training) vs (HIIT + resistance training) vs (SIT + resistance training) which I think is different from what is being discussed.
IMO, if my goal was to improve anaerobic capacity that is how I would do it or do those intervals by themselves. I would want to hit the anaerobic intervals with as high power as possible, which means fresh / rested legs.
If my goal was fatigue resistance I would stack them at the end or sprinkled throughout the ride, though I prefer to stack them at the end.
Coach Chad on the topic, worth a listen:
So racing is the best workout to get better at racing. The pros use lower importance races to get fit for their target races (and so should amateurs - if you have enough races on your schedule to do it).
CX is similar to a threshold workout in that you stay working at a hard and steady effort, it just has lots of high spikes rather than a TT where youre trying to sit on a wattage. You would prob get burned out working threshold workouts midweek then race CX on the weekend. I would just do some 30/30 midweek and race CX on weekends. The actual CX race like you said is a constant high HR event where you do sprint for position in the first lap but otherwise you’re trying to be even paced (per lap - not like an even power output on each lap). I put the power required for the given terrain (high torque stuff) but otherwise sit on SS.
If you’re ftp is actually going down thru CX season, it’s more bc the actual event isn’t training it bc it’s not important for the actual event. Tho, I think it would stay relatively constant throughout the season.
Podcast discussing all out sprints into long ride.
This could be of interest:
Combined speed endurance and endurance exercise amplify the exercise-induced PGC-1 α and PDK4 mRNA response in trained human muscle
https://physoc.onlinelibrary.wiley.com/doi/full/10.14814/phy2.12864
WU
6x (30sec sprint / 3min recovery)
60min endurance (60% VO2max)
