Check volume - are there any logic/AI to this?
Used check volume today and get this “recommendation”
5 workouts per week (recommended)
3 Hard intervals, 2x90min + 1x120min
1 easy ride: 30 min
1 Dynamic endurance 90 min
If I select only 4 workouts:
3 hard intervals 2x60min + 1x105min
1 Dynamic endurance 105min
And 3 workouts:
3 Hard intervals 2x60min and 1x90min
Why does it cut down the length of the hard intervals if I lower the number of workouts? Time goes from 7+ hours to only 3h30m.
Currently do 2 hard intervals at 60min and 90min and 1 long endurance ride. Often wonder what the most optimal would be, so try to understand the reasoning behind this recommendation.
Thanks
You got it.
But why? To what advantage?
Im sorry i must not understand your question - what do you think should happen when you select a different number of workouts per week? The same total hours, the same balance of intensity?
I would like expect the custom plan builder to keep the suggested intensity on other days when going from eg 5 to 4 workouts per week, removing only a 30min easy ride.
if custom plan builder thinks 2x90mim and 1x120min hard interval days are best for 5 workouts per week surely that should be suitable with only 4 workouts per week also?
But again it’s just to understand the logic behind the plan builder
Maybe it assumes that if you ‘only’ have availability to do 4 days a week, it’s because you have lots of off-bike stuff going on that’s going to compromise recovery? Even more so for 3 days a week.
As a general rule, if you’re going to do, say, 10 hours of riding per week, you’re very likely to get better results by spreading those hours over 4 or 5 rides than trying to compress them into 3 rides.
Okay. I would not. The optimal distribution of work is going to be a combination of workout frequency, workout time/intensity, and recovery time. So as you change one factor, the other factors should change.
Let’s say my optimum recommendation is 4 sessions a week; two hrs hard, two hrs easy, 3 days recovery in between.
If I decide I only want one session, why would a four hour hard workout be optimal?
Hi Joe,
Not sure I follow you. I agree that frequency is important and in my case 5 workouts per week is most optimal. 3 or 4 workouts per week is what life permits. But what’s the logic in lowering the intensity of those 4 workouts per week compared to 4 out of 5 workouts for week in the optimal plan?
I would agree, overall volume should change. But there isn’t much logic in lowering the volume the of the individual days, when moving from 5 to 4 days, which is what is happening.
You all are trying to make excuses for TR here when there really isn’t one.
I think there may be some different logic in place for the recommended plan vs everything else.
This is something that we may adjust in the future, but if you want to change the number of work days and still have a similar amount of load, you could do two 90-120 hard intervals and one long endurance ride where the duration of that ride is set so that estimated weekly TSS matches the TSS we’re recommending on the recommended 5-day week.
So if I understand correctly, “check volume” analyzes your recent training history and comes with the “optimal” plan including workouts lengths?
But as soon as I change from the recommendation, that doesn’t work anymore?
What I did was see the recommended volume, reduce my workouts, then extend each workout until it went amber or red to see what it still thinks is appropriate.
Interesting. That could work. With 5 workouts per week I can select 3x2hour hard intervals. And it first complain of high intensity if I change the 30min easy ride to a 2 hour ride as well. By this I can perhaps conclude that ai just need to ride a lot more before making progress? :thinking:
Still in doubt how long those hard intervals days should be for maximum gains vs minimum effort. with only 3 workouts per week it doesn’t complain about intensity with 3x2 hour hard intervals. :sweat_smile:
Thanks @JoeX :+1:
How long have your hard workouts been recently?
Both 60 and 90-minute hard workouts are pretty productive, so I wouldn’t jump straight into multiple 120-minute workouts. You could work your way up over a couple of weeks, though.
Thanks. For now I think I’ll do 1x60min and 2x90 min. Tried to change to 2x120min but then AI just lowers the intensity and even the prediction so maybe 90min are best atm.
