Yes, you should get the same result. The Kickr will fluctuate above and below the target power but quickly corrects itself with a few seconds. All trainers do this. So even over the one minute steps of the ramp test the overs and unders should cancel. As long as you test with the same power source you use when training, then it is an accurate assessment and a good number to use for your FTP.
I am glad to have seen this topic. Yesterday I got a new indoor bike and it supposedly has an extremely accurate powermeter. So comparing it to the Assioma pedals I noticed the pedals reading 6% too high over a short test when I ramped power from 100W-250W.
But if the bike is reading power at the back, that is exactly the 10W-15W loss from the chain. Makes me feel a bit better again that I did not loose 15W FTP all of a sudden ![]()
That’s good to know, because my basement gets very cold.
Around 200W my Kickr Core reads about 7-8W higher than the Assiomas after the trainer has properly warmed up.
Another data point: my Kickr Core typically reads about 20 Watts higher than my Assioma Uno after a fresh calibration of each.
Yes - I have Kickr core and Assioma duo. Upon using Assioma I discovered my FTP was 22w lower. Or about 8% lower. I think the Kickr core has compensation built in which ends up exaggerating numbers.
I recommend testing using power match and Assiomas before training further if you plan on using your Assiomas as your primary power reading source - otherwise you risk overtraining.
I have always used my Assioma’s as my power indoors and out. I would recommend everyone do that since power match is available.
I’m reading 8-10W lower on the pedals vs my kickr core as well. It didn’t used to be that way though. Just this season. I’ve calibrated a couple times but nothing has changed.
I did the same 4-5 % here ![]()
I compared both.
Assioma Duo registered into Garmin Edge 520 and Kickr Core into The Sufferfest app.
Both spindown and zeroing performed properly before the test.
I saw less than 1% difference for average and normalized power and below you have the overall comparison.
I was pretty happy that I was measuring power based on Assiomas only for outdoor rides.
However, my Kickr unit got electronic problems, and the trainer I bought as a replacement is not showing comparable results. I hope the company will find a way to fix/improve it.
Cheers!
Just to add a small follow up here… I’ve since been able to compare my Assiomas to a Stages power meter and the Assiomas and Stages were incredibly close—-within 1 Watt most of the time.
Based on this, plus the way power is measured in each case, and having done some reading around, I think my general advice to people who have such a discrepancy is be strongly biased towards trusting the Assiomas.
Probably most people would come to that conclusion a priori, but it’s always tempting to believe the higher number.
Bumping this as i’ve recently come across the variance between my Kickr and Assioma dua shi. The power relationship is exponential, when they are within 1 watt near 200 watts, though 10 watts different around 330.
This is impacting me negatively because TR AI FTP Detection thinks i’m getting a lot stronger, when in reality i’m just riding more outdoors which is showing higher figures than when I ride indoors. The Assioma app has a way to simply modify the output values, though its a static change across the entire power reading.
Any thoughts on getting these closer in sync?
Sounds like a tough one with the variable discrepancy. Might be worth trying the “Factory spindown” as detailed here: Factory spindown KICKR/MOVE/CORE/SNAP [tsg] – Wahoo Fitness Support
I agree. Mine were 10w off, did a factory spindown and now they stay within 1-3w
Will do - Thanks guys
I also have kicker 7-10 W higher than the Assiomas. But you can manipulate the kickr with the spin down to show 30-40W higher. I do that when I have TR and Zwift side by side. TR connected to Assioma for the actual workout and kickr to zwift so I can get through the levels and challenges faster.
Just take all power readings from the pedals and forget the trainer. I think it’s called power match on TR.
One power source is the ideal way to go.
You can also change the setting in the wahoo app so that the trainer is controlled by the power meter.
