AI FTP prediction 3 days in a row (?)
Might be a bug. I have the 28 day FTP prediction that is showing up 3 days in a row. The first one is a grey block the other two are green. I think that just means no change and green is a positive increase. I have not seen this before.
I have also had multiple times where I have completed a Zwift race and when I open the page to indicate the level of intensity.; Easy, difficult, hard, and very hard it logs the race twice on the calendar. Once I refresh the screen it goes back to only a single entry for that event.
This definitely looks like a bug. Let me report this to the team. :+1:
@eddie Not sure if you all accomplished anything behind the scenes but it apprears to have corrected itself now.
Good to know! I’ll follow up with the team to see if they did anything, but it seems like this may have resolved on its own once your calendar updated.
@eddie There still something a bit weird. The last FTP increase on the calendar was May 1. There was one on May 29th but it has disappeared and I think the value was around 258. So if the next one should be in 28 days it should not be July 1st. Looking into the FTP history the last recorded one is on May 1st so the June one has dropped out completely. It’s not a big issues because the numbers are similar. Just curious issue.
The FTP keeps moving one day every 24 hours. It appears to be on a 28 day rolling date. Every day it moves one more day ahead of where it was the previous day. Now the new FTP is scheduled for July 2nd.
Thanks,
Patrick
It looks like you have access to FTP Detection right now, which is probably why this is happening. If you run AI FTP Detection and accept the results, your next detection date should be 28 days from now.
Give that a shot and let me know what you find.
Ok that removes the 3 FTP that I had showing on the calendar and now it’s only the one 28 days later. When I came to the 28 day block last week when all this started happening, I’m pretty sure I accepted the AIFTP. Maybe it didn’t take but is this what happens if you don’t? Just trying to keep from running the gauntlet again. I’ve had great success with the new protocol AIFTP since implemented and am extremely pleased with results. So just want to keep on keeping on.
Thanks @eddie
Patrick
It’s hard to say whether you accepted that FTP detection and something happened, or if you accidentally didn’t accept it.
Moving forward, just let me know if you see any issues like this in the future. :+1:
Keep on keeping on! :right_facing_fist: :left_facing_fist:
