Definitely one for the meme thread!
But what about the Edge cases where the user’s forum_name != training_profile_name
Agree completely and I’d even argue that most of the users probably don’t need to be educated in order to train well and drive results. Seems like a waste of valuable resources that should be focused on stuff that really matters. If FTP was redefined (or relabeled), people on the forum would still poke holes and debate the merits of different approaches. If everything was buttoned up and perfect, that would be so boring…
I think FTP as a carrot is really what the masses want. A simple number that can be pushed higher. I think I have a decent understanding of what the different flavors of FTP are and how they can be misleading as a fitness measurement, but I’m still guilty of putting too much weight on that number.
If the goal is to more accurately measure fitness, I’d look to expand from a single FTP number to more granular numbers in each zone. Progression levels for each zone gets you part of the way, but you can’t compare progression levels across time without the context of the underlying FTP (or tFTP) that drive the actual work output. Comparing your power curve over time also tells part of the story, but is not really relevant if you have not done workouts focused on max effort for x minutes. When I want a good measure of where my fitness is at, I lean heavily on comparing the results of the same/similar workout at different times. It’s an imperfect science at best, but it’s the best approach I’ve found. I just had a Vo2max workout on Tuesday that I did about the same time last year at the same phase in my training. While my set FTP for the workout was 5 watts higher this year, I was a little fitter last year and the workout showed this (even though the interval power targets were lower for last year’s workout). As much as I’d like to see a more comprehensive way to measure fitness over times (with zone granularity), I think this is another area where it’s not a high priority for most. More carrots are good though, people love carrots.
My answer would be that training isn’t just muscle perfusion and oxygen delivery. Some athletes might still look forward to the mental toughness of an all out ramp test especially when the pain brings “hey, I can just bail out and TR will still tell me my FTP” into your frontal cortex. I find this is very similar to the “hey, third place is still on the podium” during the final minute of a hilltop finish.
Agreed. Provided the education gets real. There are some great snippets on TR site, like this one:
But if you read the forum, there is a group that dismiss FTP. And some hand waving about getting it right isn’t important, because its compensated by Adaptive Training and a progressive structured training plan driven by AI / Machine Learning that tweaks workouts by using millions of workouts and looking at tons of dimensions (that’s a technical term
). Your decision on what to believe.
Sure, i didn’t know if everyone in the support teams knows that i am a edge case like Ivy said, so on every answer there is a different member of support team on the same ticket
It’s the percent of rides failed.
So much I/we figured;-) But what’s the range? 0–1? 0–50 %? Or even 40 %—60 %?
I wonder how much of an edge case people really are. I’m sure in all walks of life be it TR power profile or ability to loose weight or learn a language most people aren’t really an edge case, there’s too many edges and most people (myself included) just aren’t special and will be an “average” person.
It sounds like you’re taking a more philosophical approach to this question, but in context
We saw your feedback; your situation is an edge case and is helping AI FTP Detection improve while it’s in beta – thank you.
it means “outside the norm in TR’s data”. We don’t have access to their data, so we just have to trust them (or not
) if they describe a particular scenario as an edge case.
100% this. Sounds like a really simple way to allow fine tracking and easy comparison (incl’ historically).
Yup, if we think of the bell curve that exists in most things, some people (or use cases) are closer to the middle where the larger population exists, with others more towards the edge of the curve (hence the name). It’s not so much about the person in this instance, but the data that TR is receiving from that user and how it lands in the system (AIFTPD in this case) relative to a larger population of users getting better & desired results.
Those edge cases are legitimate and should be investigated to see if TR can improve to handle those outliers better. But it’s important to recognize that from the many other positive comments about AIFTPD, it seems to be working pretty well overall. The results are likely even better when we note that we tend to hear more about problems than successes because people are more vocal with negative issues and than positive ones.
From what I have seen and what TR tells us, AIFTPD is working well to address a large number of TR users. I replied above to point out what I saw as a broad statement questioning AIFTPD validity on a large scale, based upon the less than ideal results of these edge cases.
Oh definitely more thought experiment!
Just a comment really, and I saw that some of the cases did need looking at and my comment wasn’t really pointed at any one person particularly.
I would like to have a continuous aiFTP detection. Intervals require max efforts.
Sorry if this has been covered elsewhere in the thread - I haven’t seen it phrased in these terms yet.
I have been guilty (so guilty) of being an over tester, and not pushing through my PLs in a plan. I would like you to take the toys away from me for my own good. I would like to push those PLs up, push my endurance at higher workloads, etc…
So, if - god forbid, I do start actually moving the needle on the FTP dial - how often will TR revise my FTP? Will that 28 day gate apply in the auto model too? What are the constraints it’ll operate within to keep me pushing up those PL’s?
Here is the thing with an FTP value…
I don’t care if you call it TFTP or VFTP or even MosesHasNoSocksFTP as long as the value can be used in real life for rides’ planning and execution.
If AI FTP detection is only good for TR training then what should one do when riding a race or any other non workout challenging ride?
More than that, a few years back on one of TR YT ask a cycling coach podcast the effect and impact of incorrect value of FTP was discussed regarding threshold and VO2 max in which even a 15W higher value shall make them unproductive.
So…whatever the advised method and nomenclature of getting the FTP value you use/ recommend please make sure the value is useful both in the whole training plan as well as in the real world rides.
And…saying all of the above…the effort the TR team is putting into this tool is quite remarkable!
It looks like someone from the team grabbed it now ![]()
I’ve been wondering if maybe they already use the information from every new ramp test (thousands a day?), to compare them to the calculated AI estimates and use the data to keep improving the AI algorithm. So hopefully they already catch new outliers where the difference is large.
One problem occurs to me though, which is that as everyone switches over to using the AI to calculate FTP and no-one uses the ramp test anymore then there will be less data available recently to see if the AI calculations are staying accurate …
TR reviews the following workouts by user’s (the performance outcome and ratings from them), as the main check against AIFTPD.
The whole point of AIFTPD is to avoid testing (Ramp or otherwise) so it’s not required for them to have any testing to evaluate or compare.
What matters to them is how the AIFTPD works in practice for your training.
I go ride outside for 2 hours with an average power in my endurance range, no matter how spikey, there’s a pretty good chance I can still complete Pettit +1, for example.
I am not here to disagree with you or protect TR. This is more of an interesting observation. I think the problems of putting a PL on an unstructured outdoor ride is much tougher a problem than most people myself included like to believe
If you look at average power it is like look at a tree and not realizing you are in a forest. To make this point go look at Spanish Needle The power average for this is about 70% of FTP which based on your logic means it is a endurance, but I think most of us can agree it is not a endurance ride.
