Advice on Choosing TrainerRoad Plan for General Fitness
Hi everyone, I’m seeking advice on selecting a TrainerRoad custom plan and integrating strength and flexibility training, given my physically demanding job and low back pain. Here’s my background:
About Me
  • Profile: 36, male, 194cm, 103kg (down from 135kg in 2017), non-smoker, social drinker, married
  • Jobs: Full-time warehouse (8h standing, causes low back pain), part-time car electronics repair (sitting)
  • Fitness Background: Occasional running/cycling, spine pain with running, TrainerRoad user for a year but inconsistent
  • Gear: Carbon road bike, powermeter, Garmin HRM PRO, Tacx NEO 2T
Training Context
  • Focus: Road cycling (minimal running due to spine pain)
  • Goals: Increase FTP, improve climbing (hilly area), build endurance (love long rides), general fitness, support weight loss (via nutrition)
  • Additional Focus: Strength training, flexibility, and balance to manage low back pain and enhance fitness
  • Constraints: Limited time due to physical job, need a sustainable plan
  • Mindset: Committed to long-term training, no races planned
Questions
  1. Goal: Using TrainerRoad’s “Create My Custom Plan > General Fitness > Discipline: Road,” which goal best combines FTP, climbing, endurance, and fitness while supporting strength, flexibility, and balance? Options include “Improve FTP,” “Climbing,” “General Endurance,” etc.
  2. Term: Should I choose a 1-month, 2-month, 3-month, or other duration to ensure steady progress without stopping?
  3. Balancing Workouts: How can I integrate strength training and flexibility workouts with my TrainerRoad plan, considering my warehouse job and low back pain?
Welcome to the forum. The key to any successful plan is consistency. You say you have used TR for about a year inconsistently which might be a sign you are trying to accomplish too much too quickly and burn out. Reading between the lines it appears you are after overall better general fitness rather then training for a specific event. So i would use that as a guide setting up your custom plan parameters. General Fitness >Road>General Fitness. Remember all the other stuff will follow when you develop your general fitness. Increase in FTP, your endurance and ability to climb better all come from better overall fitness. Since you are not training for an event i would then set your duration 6 months to a year. This would give you plenty of time to adjust things as you get more fit or better able to handle more training stress. Since you have been inconsistent in the past and have a stressful job I would lean toward a more conservative or balanced side of the spectrum to the training approach. This will allow you to better handle the added stress of weight training and the other stress in your life. Remember the body doesn’t know the difference between hustling for 8 hours on your feet, weight lifting, running, or cycling. it just sees it all as stress being applied and it needs to handle it. I may suggest searching this forum about weight training to get suggestions on how other people using TR have incorporated it into their overall training. Once you get going you can modify your plan by using the train now feature to modify the plan and increase or decrease your training load to help you to be more consistent.
Hey @DmytroUk,
Welcome to the forum! :partying_face:
This is a good question, and I’ve seen many athletes who, like you, balance cycling, strength training, and a demanding job.
I agree with @bholmlate that consistency is important, and a general fitness plan might be a good option for you.
The key to being able to remain consistent with your training is finding the right balance for you and recognizing the subtle cues from your body that might signify that something needs to change.
TrainerRoad will get you off on the right foot with a custom plan in terms of cycling volume, but you may need to adjust things to fit in your strength work.
We typically recommend strength training on your hard workout days to keep those hard days hard so that your easy days can remain truly easy. This helps with recovery between the hard days to ensure that you can “strike when the iron’s hot.” :hammer:
Work/life balance is also important, and you may feel the need to skip workouts from time to time if you’re picking up some extra stress at work. That’s totally okay, and we’d recommend always looking forward with your training and not looking back. There’s no need to make up any lost workouts or adjust your schedule.
Additionally, if we detect that you’re picking up more stress than what’s ideal, we’ll let you know and make adjustments as needed.
Let me know if you have any questions along the way! I’m always here to help. :slightly_smiling_face:
can you advice some strength training plans for my busy schedule and no access to the gym
I don’t have a specific plan that I can recommend. It’s best to work with a strength coach for that.
I do have some good reading material that might help point you in the right direction, though!
Check out the TR blog posts below.
Also, you can track all of your working sets in TR! I’ve linked a Help Center article with info on this below.
Can you afford (and have the space) for a home power rack and bench, with barbells/plates? If so, then that’s the optimum setup to get you doing squats, deadlifts, bench press and overhead press. Otherwise, maybe just a barbell set for deadlifts and a chin up bar, coupled with good form press-ups to get you started.
If you’ve got lower back pain, you really need to be squatting and deadlifting (both with good form), unless there is a structural reason for you not to be.
Well done on the weight loss too!
Kettlebells. Check out the Simple and Sinister plan by Pavel. Basic but effective.
Dialed Health has a few programs geared towards cyclists that do not require a gym.
