Enjoy the rabbit hole(s)!!
Maybe true for TR “traditional base”, I don’t know. I was thinking more of a traditional ‘traditional base’ — aka Z1/2 only.
When I did almost only z1/z2 last month, everything longer than my 5min power improved.
Oh my. This is like saying only waterboarding is real suffering and Chinese water torture is a day at the spa.
This type of discernment is a marker of the difference between pros and amateurs.
Good luck with your training. ![]()
I comes back fast. That’s the point.
you’d be slow in a group but your efficiency and ability to ride longer and farther would improve. but yeah, any group ride and you’d probably be blasted out the back asap. If thats okay with you, just go ride!
Long slow outdoors - fun!
Long slow indoors - just torture.
I think you are on the right way! As many people have suggested before me if you have the time to do z2 base there are just benefits. Make the z2 rides really disciplined, no coasting, lock in that power or hr and do long mileage. Your FTP will raise, slow but steady.
You can always build your 2-8min power at anytime from that good ae base. Build up the intensity work gradually and 2-3months later you have a race ready engine.
Good luck! And keep us updated
Every long ride I do is ALWAYS about half an hour too long irrespective of the duration.
They talk about training without events in mind some about an hour into episode 198: Attacking vs. Tailgunning, Pre-Workout Supplements and More – Ask a Cycling Coach 198 - TrainerRoad Blog
Just like in other realms of fitness, there’s definitely something to be gained by changing up your training now and then. You can drop specialty if you don’t have any events in mind.
You might consider alternating traditional base with sustained power build, or traditional then SSB then SPB, or some other combination
But like others have said, it doesn’t take a lot to maintain your base once it’s established, and you can reap greater overall benefits by alternating between base and build. You’ll be able to maintain the same speed in Z2 at a lower percentage of your FTP, and stay in Z2 at a higher wattage ![]()
At the moment I’m following traditional base low volume, plus weekend rides (plus strength work). I would prefer to be doing some VO2 max sessions, but at the moment I can’t, due to a medical issue which will hopefully be resolved in the not too distant future.
I am one of those people who can only do 2 high intensity sessions a week, or I risk digging myself a hole.
One of the things I’ve noticed just doing Z2 is how easy it is to regulate my stress levels - both mind and body. (and I have some significant life stresses going on at the moment). i think we all need to check in with ourselves from time to time and make sure we have not just become accustomed to high stress levels.
I often think some of my friends are tired but wired, but in that state they are less likely to listen.
A few years ago I trained for a 24 hour mtb race by doing 3 months of only Z2. Once I was scheduled to put in a few efforts I was the fastest I’d ever been. I only stopped once in the race - to get changed as it rained for 10 hours straight and won my age group. It didn’t impair my ability to suffer.
I don’t want to ride for 7 hours at a time in training and I don’t do 24 solo anymore, but my current training is reminding me of the benefits of early nurturing for future gains.
This is perhaps the single greatest benefit to Z2 training. Training below AeT provides heaps of fitness gains but barely stresses the various systems of your body. It’s also the very first I noticed when I stated low-HR training, I wasn’t ‘wired & tired’ all the time.
I know this post was from 5 years ago, but I just found it…so what happened after a year of just doing traditional base training
Anything is possible, but I wouldn’t hold your breath on an answer since the OP hasn’t visited here in over a year.
How does the table look on a W/kg basis?
I did that and as many here said, you can become a lot faster minus the punch. For long solo tours totally fine. For groups not so much,
Check your CTL and ramp rate.
My FTP during base increases about 1w/1pt of CTL. Typical values could be between 0.5 and 2.
The closer to the “2” you are, the more fun you’ll have with that continuous base approach.
I didn’t really track accurately in strava or intervals but I did lose weight from 76-77kg to 72kg
I build up to around 13h, longest ride usually 3-4h with a few 5h ones
You would plateau very quickly and not gain much fitness in the end. Unless, of course, you ramped up your endurance volume significantly. But that also runs into practical limitations (do you have time to ride 2 x 5+ hours on the weekends?).
It’s just not a good idea IMHO.
In practice what I would recommend is placing your emphasis on e. g. endurance if that is what you want. That means you do two workout sessions with intensity and fill the rest with endurance rides. Importantly, at least one of these endurance rides should be long.
