2026 XC Bike & Equipment Thread
Take a look at alugear for threaded chainring alternatives to SRAM as well.
140 on a bike used for XC is a no go for me.
If you’re talking about the Canyon, I agree. I would ideally have a 130mm 34 SL or something like that. I think that’s the way XC is heading anyway (for 29" bikes at least)
I just put a SRAM 90 RD and shifter with an XO T XS-1295 cassette on my new sub 10Kg XC build. It shifts really very well. Very fast and clean. Lever effort is low too. Way better than SRAM’s previous mech drivetrains. The only negative is you get just two downshfts per stroke instead of three like previous, or all with electronic. That said, it can downshift across the cassette faster than electronic does. .
The wolftooth pedals are something else. I have been on some form of SPD since the early 90s. I remember tipping over in the gate a lot as a 6 year old learning clipless on a BMX bike. SPD pedals have just been SPD pedals to me. I tried the ISSI for a while, they were fine, but XT level pedals have always just kind of worked.
Then I got a set of the Alt pedals from wolftooth, and never knew you could think, “damn, these pedals are really nice.” I am using them for CX and they are so good. Eventually I am going to blow up my garmin XC pedals on a rock, and will have to move to a spider PM and get to use the wolftooth pedals on my mtb.
Anyone destroyed a garmin xc pedal? I am surprised mine have held up after some impressive rock strikes.
One of my garmin rally xc pedals has a broken metal piece that goes around the sensitivity mechanism for ease of clipping and out. Other than that, they’ve been pretty solid, no dropouts, and pair up everytime I ride. I don’t use them on my mtb since I have a Rotor, but they were on my gravel/cx bike. I take them off for cx races though since they are a pain to clip in as quickly as I can my xtr pedals and I don’t care about power when racing or post race.
Regardless of the details of that bike, it will be nice to have something put some downward pressure on the bizzaro prices on most mainstream bikes.
I have destroyed pedal bodies on the favero assioma pro mx pedals. What do you notice with the Wolftooth pedals compared to say Shimano?
I like what I am seeing on that bike
The engagement has a really clean mechanical lock to it. On my Shimanos there are times the cleat just kind of slips in and you don’t feel it lock in. You get a really positive feed back from the wolftooths. The tension is way higher on them. I run all my shimanos and garmins at max tension. I have my wolftooths at about half tension.
The best way I can describe it, it is like going from good flats to really good flats. There isn’t a single specific thing that makes them feel better, they just do though.
Have you noticed any difference in foot stability vs Shimano XTR pedals. Is the increased pedal body contact area noticable?
That’s what I noticed immediately, feels like there is a ton of additional contact area. It felt significant enough that I could comfortably run them at the lowest tension setting and still feel connected.
Oddly, I have XT trail frames on the other bike and never felt the benefit from the frame with any shoe I have.
Foot stability is not something that has ever cross my mind to be honest.
That looks like the Cervelo that’s not being made any longer
A lot of this seems to just come down to the shoe / pedal combo for how much the pontoons touch. It’s a fine line between the shoe making too much contact and the clip in/out feeling vague vs the pontoons sitting ever so slightly above contacting the pedal and the interface feeling slippery, rocking, or even like a single point of contact. At one time I was running a really cheap shimano shoes with high end time pedals because the stack up happened to work so well. The adjustability of the crank bros pedals with their step pads are nice for this but I just don’t like the mechanism and have had a lot of durability problems. Currently using s-works recon shoes with time xc-12 and that interface is decent now that I switched to the silca 3d printed ti cleats. It’s like a puzzle sometimes!
I have always run the xt or xtrs. I got the wolftooth one sided Del’s for my gravel bike and they are noticeably nicer than Shimano in every way. Easier click in, better retention, noticeably more platform to pedal on, and significantly lighter than even xtr. I’ll definitely be getting alts for my top fuel.
So whose riding the new Spark RC?
Been waiting for this one for like 2 years now. -17° rise for the Allied Duet stem.
https://alliedcycleworks.com/collections/parts/products/allied-duet-mtb-bar-stem
Same! I’m glad to see a 90mm too as they previously only went up to 70mm I believe. Wish they would do 100…
