Hello,
Anyone here have issues with there Kickr wearing belts? I have (2) 2016 units that my fiancé and myself use a good amount. These are the both the 2016 model and have been totally trouble free since new. One unit is still 100% perfect(knock on wood) and the other is showing some strange belt wear. These are the units with the ribbed belt and not grooved like the newer units. What we are seeing is the belt not staying centered on the large cassette pully. The issue with this is the side of the belt is wearing down and throws off small rubber chunks the size of grains of sand. I tore down both units to inspect all the bearings and both units have bearings in good shape. The only difference is the unit with the belt wear uses a belt tensioner that is just two bearings, where the other unit uses a tensioner that is two bearing set in a steel pully with tapered sides to keep the belt aligned. From what I have found this steel pully is still used on the new units.
As a little test I swapped tensioner pullies from trainer to trainer to see what would happen, and the unit with the belt wear still had an off centered belt with the new pully design.
Another interesting thing i have noticed is that if you rotate the trainer in reverse the one with belt wear makes a faint belt squeaking noise and the good unit is silent.
I have reached out to Wahoo a few days back and have not heard anything, so I figured someone on here might have had a similar issue?
