1:1 - does it matter how you consume?
Hi. I’m going to try upping my carb intake in readiness for an event.
I understand the whole 1:1 thing but does it matter how I take onboard - in my case - 90g?
Ie I have gels that are fructose only. If I have 2 of them meaning my fructose is at 40g can I make up the other 50g with my own mix at 5g fructose/45g maltodextrine?
Hey, @urban_sapceman my advice is not to over think it. Just mix with an approximately similar amount of dextrose & bob’s your uncle. But if you want to match 1:1 down to mg precision I respect your attention to detail.
One thing to think about is this: table sugar (sucrose) is nature’s 1:1 ratio since it’s a disaccharide made up of one part fructose and one part glucose. Once dissolved in water you automagically have a 1:1 solution. No measuring required.
Thanks for replying.
WOW - I did not know know that about table sugar! I have been spending good money at supplement stores on packets of maltodextrin and fructose!
Not everyone can stomach 90g hr of table sugar, so test it before you use it in an important situation. My stomach is a lot happier on malto/fructose when going for higher dosages.
I’ve been testing highly concentrated sugar and water in a soft flask. I like it so far. It’s like gulping maple syrup and I chase it with water.
Packets! I buy 8 pounds of maltodextrin for cheap on amazon. I mix it with cheap gatorade powder for some taste.
Unless you are at the pointy end of the peloton and training your gut I wouldn’t over think it as Brennus said.
I did my first long gravel event last year and I carried 300grams / 1200 calories of gatorade and maltodextrin in a hydration pack. That is 60 grams per hour for a 5 hour event. Plus I had some bananas and a couple of bars. It was the limit of what my stomach could take and I had plenty of energy during the whole event.
Btw if anyone wants to read how these ratios came together. One of the best articles out there is still…
Totally agree with all of the above, I tested straight 80g of sugar in a bottle and my stomach said NO thanks. Meanwhile a mix of Malto, Fructose with some lime juice out to 100g? No problem! What the heck stomach?
Your stomach clearly has refined taste. Mine on the other hand is really happy just guzzling.sugar. I usually add lemon juice to taste. If you take this route, you also have to consider how you take in salt which is usually part of a commercial mix.
