Zero Friction Cycling efficiency data for SRAM flat top chains
I don’t want to spoil this vid, but a lot of the video is spent talking about other-than-SRAM chain compatibility with SRAM drive trains.
All speed factors quoted for cleaned & lubed chains (not factory grease)
($$$$)SRAM XXSL → Speed factor comparable to Axis Road Red, not as good as Campy, Shimano Ultegra, Shimano Dura Ace
($$$)SRAM XX → Speedfactor same as XXSL
($$)SRAM XO → Speed factor better than XXSL, XX. Same as Ultegra/Dura Ace
Would rather you would so I don’t have to watch it
:+1: :joy: Understood. Well the results are right there in the image, if it helps.
Haha I’m so grateful to him for all he does, but I think he’s the only youtuber that has ever made me consider starting my own youtube channel. It would literally just be 5 minute summaries of his videos, released a few days after each of his. I’d aim to be to him what Lanterne Rouge is to the full broadcast of a world tour race :joy:
Could someone who’s not sitting at work trying to read the graph off their phone summarise please, is the Transmission chain faster than an XTR chain?
Does it last as long as the old SRAM chains?
I edited the post
Graph summary: Campagnolo or YBN chains are the fastest!
I watched some of the video.
Conclusion for an SRAM rider: don’t use a different chain because the AXS system sprockets are designed to fit with the flat top chain’s larger rollers. A Dura Ace or other regular chain would see the Sram sprockets like worn out sprockets and you might have skipping.
The more expensive Sram chain was the fastest Sram chain.
And, don’t ride on factory lube if you care about watts. Properly lubed/waxed, the fastest Sram chain was as fast as Dura Ace / Ultegra.
Opposite? For road the cheaper Force chain uses less power than the Red chain. Thought it was the same for the new Transmission chains.
Yes the cheaper XO Transmission is faster than the XXSL. I wish I had known before i bought a spare.
Yep. Cheapest was fastest. Because SRAM cares about their customers. Or maybe they just don’t know how to design a good chain. I can’t tell which.
I could have got it backwards but they were testing mountain bike chains here. The whole XO, XXO, XOSL, whatever are still greek to me.
Yes, the cheaper SRAM chains, when tested by Ceramic Speed, lose less power when stripped and wax lubed. The factory grease is terrible.
Some small watt differences on the road chains, between Shimano drivetrain and SRAM drivetrain.
UPDATE: Now that YBN makes a Flat Top chain, what are folks thoughts? I run Red XPLR which requires the Flat Top chain, and I am not in favor of risking the spendy Red cassette by using a non Flat top chain… Given that the SRAM Flat Top chains are known to perform poorly in terms of drivetrain friction, has anyone here tried the YBN Flat Top in hopes of getting a few more watts out of the Red drivetrain? I am assuming a waxed chain as well in all cases here, I just have not really seen any reviews of the YBN Flat Top chains yet, and this seems pertinent to this (older) thread.
I see on Amazon that 100 were sold but only 3 reviews so far. Not that Amazon reviews hold water.
Maybe I will buy one and give it a try.
It’s on order. If I can remember I’ll give an update after stripping and waxing .
Edit; the link was for a SRAM chain. My error for not reading the fine print. Now I don’t have to worry about snapping a chain.
KMC are launching one
I suppose they will release it soon, as there has been some recent posts in the social media.
Update. I ride/race the Red XPLR 13 speed drivetrain for gravel. I am trying out the new YBN flat top chain, my results so far: back pedaling the bike with the YBN, with a straight chain line, one can definitely feel that the YBN has less friction than the Red E1 chain. Out riding, the YBN chain seems a tiny bit noisier, and does not shift quite as perfectly as the Red chain. But, that is not to say that the YBN chain is a problem in any way, it never misses a shift, or is slow to shift, it is just not quite as “perfect” shifting as Red. Given that folks report shorter wear life with YBN chains, I am going to use the YBN for races, and continue using SRAM chains for the rest of my riding. All observations were with a Silca waxed chain.
You feel the difference in chain friction while backpedaling? :face_with_peeking_eye:
If you are running SRAM - what is the consensus on the best bang for your buck chain in terms of overall efficiency?
I run the now old Force XPLR group and am debating between the old 12 speed flat top or new 12/13 flat top chain. Is Red worth the premium over Force?
My understanding is there is a small weight saving and some plating that might reduce friction.
