Workouts not syncing to Garmin connect
Has anyone faced issues with trainerroad workouts not syncing to garmin devices? There seems to be a problem where workout data is not appearing on garmin connect after being logged in trainerroad. Do share some tips. TIA
Hey @FelixLeo,
Welcome to the TR forum! :partying_face:
I’ve linked our support doc about pushing TR workouts to your Garmin below. I’d recommend reading through that to ensure that you’ve gotten everything set up properly.
A few quick tips to note though are:
  1. Make sure you’ve authorized things to sync
  2. Double-check that the workouts you want to sync are set to “Outside” and within two days from today (we won’t sync workouts more than two days from now).
Let me know if this helps or if you need further assistance. We’ll get things sorted out one way or another! :mechanic:
Garmin connect (the app, not the ability to connect your garmin haha) is one of the most finicky apps I use. Some days, it syncs within seconds, others, it’s an hour or more to sync anything, be it a workout to start a ride or my stats from after the ride. Sometimes does fine over BT, others it has to be on my home WiFi. No rhyme or reason for when one works or the other
Garmin connect: if it doesn’t synchronize, a restart of the app fixes it for me.
