Why is it called training volume?
Why is it called training volume if training volume only concerns duration and frequency? (2 parameters)
I’m confused because I thought volume required 3 parameters.
Maybe there is a nifty story as to why it’s called training volume and not training area.
profshop161100030
Duration, intensity, and frequency :thinking:
Be square or get up and rhombus!
Because volume also means an amount or quantity of something. Tis the English language.
If it only contains 2 parameters you are not doing enough of it to make a substantial amount (volume) :wink:
Drafting geek alert. Training Volume is based upon time spent training, and frequency of training. In a sense, it creates a 2-axis coordinate system that can be uses to show “volume”.
I see time as the vertical axis (hours as units) and frequency as the horizontal (days as units). You can create a line graph between the time spent training on each day. When you do, you effectively create and “area” of training under that line. I could see calling this area “volume” and is a decent visual representation of the amount of training.
I’m with @Brycycle - that should be training area then if its 2-D…
we’ve been living a lie
Crap, need more coffee… totally right there, doh! :stuck_out_tongue:
but seriously as @handynzl says… “the number or amount of something in general”
Solved my headache right here.
