Which heart rate monitor?
I have a polar H7 that’s I’ve used for years. Outside an occasional battery replacement and having to pull the battery and do a reset when reading get wacky, it’s been solid.
I also have an Garmin HRM Dual which works very well and has a machine washable strap.
I’ve purchased too many hr straps over the years. My last purchase, about nine months ago, was the tickr fit. No more contact problems or battery issues. It just works every time.
maaaan, had the worst time with the Garmin DUal; it went through 5 batteries in a couple of weeks.
Returned it and got an H10; seems to be working fine.
Hi folks,
Must be me!
See the pics where the app has picked up my garmin dual HR monitor but has no rate reading? This has happened last couple of work outs. And hasn’t happened on the road when using garmin 830. Any ideas? Seriously frustrating when these components just stop working for no reason…
Thanks
Ed
The best for me has been the Polar OH1+. It’s not a chest strap, it’s an optical arm band. It’s been rock solid and highly accurate.
Polar H10 (or H9 for that matter)
Rock solid, good battery life and quick pairing.
Have had multiple Wahoo bands that quickly stop working.
I had the exactly the same prob - just in a different app.
My Garmin HRM Dual actually broke in two! The plastic around the screws at the back broke. Don’t ask me how because I don’t have a clue. Never changed the battery or opened the back.
+1 for the Polar H10. Super fast connecting and I find it a lot more comfortable. Can’t comment about the accuracy or durability though.
Thanks folks. Polar H10 is on order. Done with the Garmin HRM! Cheers.
Second this. I found my old h10 after my second wahoo tickr failed. Updated the firmware and it’s been rock solid.
Polar knows how to make a quality heart rate strap. It’s worth the money
My CooSpo HRM has started not reading over the weekend. It beeps instantly to indicate there’s charge (which it should do as the battery was only new 2-4 weeks ago) and then 5secs later it beeps again to say its switching off. Tried a new battery anyway, a new strap, thoroughly made sure the contact points were clean but it’s the same behaviour. It has actually been one of the most reliable (up till this) HRMs I have had and I was tempted to get another but I’ve took a punt on the TickR.
Late posting this since you went with Polar. Thought I would share anyway. My experience with Wahoo is okay, but the straps seem to wear out fast and I’m not even that big of a sweater.
I’m probably going to go with 4iiii since I like the PM.
Just a quick second on the Polar OH1+. Best HRM I’ve ever owned, and I’ve owned (too) many. Let me also add how much I personally prefer an arm band to a chest strap – remarkable how constricting a chest strap feels in comparison.
I agree on the arm band. It definitely works very well.
For those of you using the Garmin belt with TR on an IPad, how are you connecting the HR to your iPad? I’m using an IPad Pro and can’t seem to get my Garmin HR to connect to TR on the IPad. Wondering if I need an ANT+ dongle…thanks!
Do you have a dual HR monitor? It may be that your HRM is not broadcasting on bluetooth. My old Garmin chest strap would only broadcast on ANT+. Your iPad will only be able to pick up Bluetooth signals. I don’t have an iPad but I don’t think you can just plug in a dongle. I don’t think apple supports ant+.
A way round it it would be to get a ant+ to BLE bridge, or get a HRM with dual Bluetooth and ANT+ output. Garmin do the dual model. I have the Polar H9 which does Bluetooth and ANT+ and broadcasts on both at the same time.
I had to go back to using my laptop after getting my Garmin strap. I think only the pro does dual transmission, just another excuse to charge more!
Agree, I just got a new polar 10 as well. My old6 is still solid too!
Do HRMs degrade over time? I have the basic Garmin Dual, have used for 3 years or so and it’s mostly been fine. I only use it with the bike. Recently, it’s had a really hard time pairing with my trainer. I changed batteries recently so that’s not the issue. I wet the back, and it used to connect fairly easily. Now I spent upwards of 10 minutes trying to fidget with it, sometimes still to no avail.
I’ve thought about upgrading anyways, although not sure if a superior HRM would function any better?
My Garmin straps need to be replaced every 2-4 years. Just the strap.
Make sure it’s not paired to other things.
