When to replace wheel due to torn spokes?
I’m doing most of my outdoor rides on a Trek Crockett 5 gravel bike. I’ve had the bike for 5 years and 20,000+ miles without any issues. However, in the past two months I had two torn spokes (without any obvious cause such as hitting a pothole).
I’m wondering, at what point do I stop replacing individual spokes ($40 a pop at the local store) and spring for a new wheel (~$200 if I can get it). Are spokes at some point just worn out and start breaking?
I would agree with iamholland. Time for a rebuild or at least a re-tentioning of all the spokes. I had a wheel that just would not stay true (no broken spokes though). I brought it into the shop they relaxed the entire wheel and re-tentioned the whole thing. Problem solved. I imagine something similar would work for you. I would however make sure the shop knows what they are doing with building wheels. It’s a bit of a dark art and is easy to screw up.
Old timer’s (worked in a bike shop in the '80s, when we had a VHS copy of American Flyers playing constantly on the shop’s TV) take here: A well-built wheel should last well beyond 5 years assuming no crashes or abuse. Problem is, “well-built” – or at least “well tensioned” – is pretty rare. Most shops let the bikes they sell out into the wild with poorly tensioned wheels, and they almost never do the requisite re-tensioning after the first month or so of riding. Wheel building and truing/tensioning aren’t dark arts, but they are sadly becoming more rarely found skills. Your best bet (easier said than done) is to find a decent wheel person at an LBS and have the wheel properly tensioned and trued. It doesn’t need to be rebuilt or replaced unless it’s really been crashed or abused.
An aside: wheel-truing and tensioning are not difficult skills to master, and it’s super satisfying to bring a wheel up to its potential. In all honestly the hardest parts about replacing a broken spoke on an otherwise good wheel are having to deal with replacing rim tape and removing the cassette on the rear wheel. Try giving it a shot – there are countless youtube videos that should get you most of the way there. Anyway good luck!
I second this. Paying $40 to replace your spoke is OK for once. But if you’ve ridden 20k+ miles in last 4 yrs, it’s time you learn some DIY! It’s not hard and the guys at the LBS just watched the same YouTube video you will (I know for sure
Bc I worked there).
Another option is to upgrade wheels. If these are entry-level wheels, maybe this is an opportunity for an upgrade.
don’t agree with that… I build a set with the musson book as a reference guide, and they are as solid and true as the first ride (after 2+ years on a MTB).
As mentioned above, it’s no dark art, but it’s a precise job, if you miss a step, sometimes you have to go back 5 steps to correct it… so the first time probably takes very long (at least in my case).
Agreed on the tension part, tension should be as even as possiblle per side, and not too loose or too tight, but the bandwidth of proper tension is pretty large and way less important as even tension.
Anyway, building/truing wheel is a nice skill to have and it’s pretty satisfying to ride your “own wheels”
for the main question in this topic… If the wheel was not proper tensioned after the first replacement (maybe it was way out of whack and the after replacing they could not get the right balance of true and even tension… it’s easy to get the wheel straight, but just turning the nipples without looking at the overall tension, but a good wheelbuilder would check the tension and try to get a straight wheel WITH even tension. that requires some more dedication (not experience, anyone can learn / do this).
So I would bring this wheel for proper inspection to someone how knows what he’s doing, if the spokes are nice and even, and proper tight, they should not break. If they do, it’s probably fatique and you need to replace all spokes or the wheel. But I would only conclude that after I know the previous spokes broke when the wheel was in good condition (currently, that information is missing)
Not really, especially when comparing to DT Swiss wheels. If the prices were similar and it was another brand maybe, but DT use good components and are well built so you’d likely do worse as a first attempt.
