I got a the TacX trainer last year and used it a little for indoor training. I now have a little better set-up because I got a whole new back wheel and tire, so I am not wearing my road/outside riding equipment out.
My main question is - Is the trainer appropriate? Can it serve as a good trainer for power readings and workouts? I have not invested in TrainerRoad yet because I do not know if the trainer is suitable. I did some of my own structured workouts last winter, but I do not know if they helped much.
Secondly, I do not ride with a powermeter, only a HR monitor. Maybe someday I will afford a powermeter - I would like to do the beginner plan and lose weight and rise my FTP, and be in shape to race in the summer months. Basically will the trainer I have be suitable for my goals? I am 205lbs and could afford to lose 10 or 15.
I’d suggest adding a Wahoo cadence meter ($40) and a small computer (lezyne micro c $99) so you see these values on your outside rides to help with pacing and effort. I don’t have a power meter on my outside bike (yeti but with cadence and HR I am able to control power output via cadence and pace my overall exertion monitoring m HR.
Riding indoors on the trainer has given me the data I need to adapt my riding outside.
Last year I bought a vortex and went from 147 FTP
(untrained) to 263 and 3.83W/Kg. I used a generic Amazon speed/cadence sensor (Coospo) and HRM (Megane).
Vortex is fine but is way off on power, especially at higher powers. I’ve had/calibrated a few, and if you get it right on the edge of ‘too tight’ on the tacx app it will be near enough correct at lower watts, but still likely 20-30 watts over at higher watts. Possibly a bonus as it’ll make VO2 intervals a little easier…
I have EXACTLY the same experience. I always aimed very close to the ‘too tight’ for reproducible workouts, but it turned out (after purchasing a Stages PM) that my VO2max abilities were not as good as suggested by the Tacx Vortex numbers.
The particular issue with the Vortex is it reads high at lower wattages and (very) low at higher wattages. Not a deal breaker, but worth knowing if you’re going into a VO2 interval for the first time after using one expecting to sail through it!
Appreciate the help on this. I jumped in an subscribed. Now just gotta stick to the workouts. I am going to look into a speed/cadence sensor now. I am curious how the structured training will work with mixing in my own rides at random on the road? Warmer weather will get me outside to ride for sure.
